Lost Spark in Rear Cylinder
Old Jun 29, 2011 | 10:06 AM
motogomojo's Avatar
motogomojo is on a distinguished road
There is no spark coming from the rear plug.(Checked with more than one plug)
Is this most likely a coil issue? Also is it just a coincedence that the alarm stopped woking at the same time?
If it is most likely a coil, should I replace the front as well?, and where is the best place to buy a replacement?
02 Bike has 22k miles.
Sorry for all the ???'s
Little online time at work = quick post
Thanks in advance.
Old Jun 29, 2011 | 10:12 AM
For a little extra work, you can replace them with CBR stick coils, save some weight and get possibly a little performance from it.
I know it doesn't answer your question, but if you go that direction:
https://www.superhawkforum.com/forum...k-coils-22773/
Old Jun 29, 2011 | 10:15 AM
If you want to go with the stock set up here is the info:
Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts
Pos. #6 and you don't have to but you might also want to replace pos. #8 at the same time.
I would replace them both as the plug wires are 9 yrs old. So either way you choose to go, it would be a good time to look into swapping them out.
As for the alarm, I do not believe that the 2 issues are related.
Old Jun 29, 2011 | 11:52 AM
kmm996's Avatar
kmm996
Mine did the same thing way back when... Rear coil failure. No issues since.
Old Jul 12, 2011 | 05:39 PM
motogomojo's Avatar
OK fellas......
New coil, plug and wires....still no spark.
Where do I go next
Alarm fixed.(fuse)
Sidestand switch has never worked ...would this cut spark to just one side?
14 days of no riding .........I need this resolved!
Old Jul 12, 2011 | 10:00 PM
motogomojo's Avatar
Effin Co-worker!!!!
Thinking back on what changed from my bike running great on the way to work,to running like **** on the way home,I remembered someone telling me that a co-worker kept kicking the underside of my rear fender with his steel toe boot to trip the alarm.
I will confront him about this tomorrow.
He rides a Harley and there has been some minor joking between both of us about our taste in bikes,but I never touch a bike that is not mine ....let alone kick it!! WTF!
So while cranking the ignition I tapped on what I think is the ICM with a screwdriver, which happens to be right at the rear fender where the douche bag was kicking, and lo and behold I get intermittent spark.
So i think I need a new ICM as I do not see any loose connections or solder joints. I bet a relay or something is toast now!
Question#1 Do I make him pay for the new part?
Question #2 Can someone tell me the actual part name/number?
The manual is a little confusing as the picture shows nothing for a 2002 where this part is located (right under the seat locking mechanism)
Attached Thumbnails Lost Spark in Rear Cylinder-dscf2833.jpg   Lost Spark in Rear Cylinder-dscf2834.jpg
hondavtr1000sp2
Nov 17, 2014 09:07 PM
jefejrs
Mar 10, 2013 02:19 PM
Biff
Jan 29, 2013 05:13 AM
BiggDaddyKool
Jun 22, 2007 06:33 AM
jimbobgrogan
Nov 13, 2005 11:54 PM
