Lost Spark in Rear Cylinder
There is no spark coming from the rear plug.(Checked with more than one plug)
Is this most likely a coil issue? Also is it just a coincedence that the alarm stopped woking at the same time? If it is most likely a coil, should I replace the front as well?, and where is the best place to buy a replacement? 02 Bike has 22k miles. Sorry for all the ???'s Little online time at work = quick post Thanks in advance. |
For a little extra work, you can replace them with CBR stick coils, save some weight and get possibly a little performance from it.
I know it doesn't answer your question, but if you go that direction: https://www.superhawkforum.com/forum...k-coils-22773/ |
If you want to go with the stock set up here is the info:
Honda, ATV Parts, Scooter Parts, Motorcycle Parts,CRF,CR,MX Parts, Goldwing parts Pos. #6 and you don't have to but you might also want to replace pos. #8 at the same time. I would replace them both as the plug wires are 9 yrs old. So either way you choose to go, it would be a good time to look into swapping them out. As for the alarm, I do not believe that the 2 issues are related. |
Mine did the same thing way back when... Rear coil failure. No issues since.
OK fellas......
New coil, plug and wires....still no spark. Where do I go next:confused: Alarm fixed.(fuse) Sidestand switch has never worked ...would this cut spark to just one side? 14 days of no riding:( .........I need this resolved! |
2 Attachment(s)
Effin Co-worker!!!!
Thinking back on what changed from my bike running great on the way to work,to running like shit on the way home,I remembered someone telling me that a co-worker kept kicking the underside of my rear fender with his steel toe boot to trip the alarm. :mad: I will confront him about this tomorrow. He rides a Harley and there has been some minor joking between both of us about our taste in bikes,but I never touch a bike that is not mine ....let alone kick it!! WTF! So while cranking the ignition I tapped on what I think is the ICM with a screwdriver, which happens to be right at the rear fender where the douche bag was kicking, and lo and behold I get intermittent spark. So i think I need a new ICM as I do not see any loose connections or solder joints. I bet a relay or something is toast now! Question#1 Do I make him pay for the new part? Question #2 Can someone tell me the actual part name/number? The manual is a little confusing as the picture shows nothing for a 2002 where this part is located (right under the seat locking mechanism) |
