california smog equip.
Old Feb 19, 2008 | 07:52 PM
PRTSMN's Avatar
PRTSMN is on a distinguished road
hello to all. by any chance has somebody removed the evap system, or know how to. i have recently just purchased it and the previous owner half as#ed the disconnecting of the pair system & evap system. i have read on how to disconnect the pair system and have accomplished that. any clue on the rest would be great the charcol can on the front is ugly.
Old Feb 19, 2008 | 07:55 PM
I've got a writeup on my website. It's pretty old and doesn't have any pics, but it you have a clue...um, I mean if you're mechanically inclined then it'll get you though. I have PAIR removal instructions too. I don't have a CA bike so I've never done it personally. Can't be that hard.
Old Feb 22, 2008 | 11:25 PM
PRTSMN's Avatar
smog.
i wanted to thank you very much for your help this is my first bike still trying to learn my way around them.
Old Feb 22, 2008 | 11:54 PM
if you get stuck, let me know as I have a Ca bike and have removed the system a long while back
Old Feb 23, 2008 | 09:53 AM
Killemall's Avatar
Beside the weight saving, and a cleaner engine area, I can't see any other benefit in removing the PAIR system. Am I wrong?
Old Feb 23, 2008 | 10:32 AM
JesseW.'s Avatar
JesseW.
removing or disableing it keeps it from backfiring on deacceleration. fixed mine anyway.
Old Feb 24, 2008 | 11:18 AM
..and less heat in the exhaust.
Old Feb 26, 2008 | 03:27 PM
speedkelly@aol.com's Avatar
SMOG
what year bike do you have?...early california models have less smog crap...later models..gets a bit more interesting?
You wil need a manual...can be download from this site....go read my little rant on this?...do a search..
I had to block off no less than "7" lines?....go figure....afterwards my bike ran great..2005 model...actually used a little more gas than before...but once I had removed all the smog, I never had any of the normal superhawk problems...backfiring...sudden stalls...or cutting out at the lights....also..no more bike stopping after gassing her up....
On the attached picture..is the carbon cannister and bracket...pair valves and hoses...also the round valve which is between the two pair valve covers...now there are two more valves like this on later model superhawks...one is between the carbs...the other is behind the right hand radiator...this can be pulled off without removing radiator..give it a good hard yank...many people just remove the large cannister and think that is it?....there is a lot more to it than that!...good luck.....to do the job right....you will need a bunch of hose caps some silcone...zip ties...and a few screws.....remove gas tank...airbox....and let the fun begin?
Old Feb 26, 2008 | 03:29 PM
pair valve cover
also helps if you have some of these
speedkelly@aol.com
Aug 10, 2022 04:39 PM
cal2az
Aug 7, 2009 08:47 PM
CentralCoaster
Jul 10, 2009 01:05 PM
ff
Dec 26, 2008 09:30 AM
CNI Dawg
Nov 16, 2005 10:07 PM
