Shimming the stock carbs
Old Feb 29, 2012 | 09:52 PM
eersfanpilot's Avatar
New Hawk Rider
eersfanpilot is on a distinguished road
Ive done the bafflectomy and now have the lean carb cough. Can someone link me to a writeup that I can follow to shim the carb needles. I have searched but cant find a "shimming guide for dummies "
Also, do I need to re sync? They are fine at the moment, just running lean.
Old Feb 29, 2012 | 10:01 PM
This is I think the benchmark. https://www.superhawkforum.com/forum...-set-up-24769/
I have 2 bros carbons and used this for a baseline and go pretty close. How do you know they are sync'd fine? While you have it apart at least put the valve on the front carb to do the sync if you chose later.
I jetted then synced but not the same day. Jetting is more important
Old Mar 1, 2012 | 06:33 AM
New Hawk Rider
Thanks. I did come across that write up and was reading through it but wanted to double check. So according to this, it says to buy and install "a set of #48 pilot jets (per Dan Kyle & HRC)". Is this required? Can you just shim the stock needles as some have suggested on here?
Old Mar 1, 2012 | 07:35 AM
I dont think I changed the jets & it was fine. Just be real careful about the choke fittings. They are plastic where they bend 90* into the carbs and break easily.(effortlessly)
Old Mar 1, 2012 | 07:46 AM
jay956's Avatar
Why is that thread still not a sticky?
Old Mar 2, 2012 | 05:11 AM
00SUPERHAWK's Avatar
Snap, Tap or Nap!!!!
00SUPERHAWK is on a distinguished road
I have a spot on part throttle (maybe less than 1/8) where I get a good bit of bucking. I happends primarily when bike is cold. But will do it if I cruise in 6th at 3k. Did some reading on here and it may be a "Lean Cough"? Not sure. Haven opened up the carbs yet to see if PO did any work to them. Just wondering and throwing it out there.
Old Mar 2, 2012 | 02:43 PM
New Hawk Rider
Thanks
Old Mar 3, 2012 | 06:44 AM
Stuck, as requested!
Old Mar 3, 2012 | 06:15 PM
GlockPointer's Avatar
Connie Demico does toad?
Why on earth be at 3k rpm in 6th? What wouldn't buck?
Old Mar 4, 2012 | 07:17 AM
Sorry thought about my post after I put it up and thought that was dumb!!
It was a of the top of my head statment, more like any gear around 3k. As if your in traffic and at the part thottle cruze around 3k.
Old Mar 24, 2012 | 08:25 AM
zxbud's Avatar
Buck
Mine won't and will accelerate smoothly in 6th. At 2500r's it will cruise ok but is a little snatchy accelerating if not shifted down to 5th.
Old Apr 1, 2012 | 07:26 PM
Byrdman's Avatar
Super Byrd
Thanks
VThokie412
Feb 17, 2012 06:34 PM
uchi
Jul 19, 2010 06:19 AM
scarface
Jan 1, 2009 08:09 AM
redman
Aug 1, 2007 05:28 PM
mojo
Aug 22, 2005 06:44 AM
