Gear Shifter
Old Mar 15, 2012 | 07:41 AM
millerwl71's Avatar
millerwl71 is on a distinguished road
Gear Shifter
Hi,
I have a 98 superhawk and wondering what other shifters are compatible with my bike. They don't have any on ebay, but have a ton of other Honda ones on there. Thanks for the help!
Old Mar 15, 2012 | 07:51 AM
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
Is it broken? IIRC you can use a VFR shifter (can't remember the years exactly), except that it connects directly to the transmission cog and makes the bike GP-shift (1 up, 5 down) vs standard. You can also flip the connector on the transmission cog to accomplish the same thing if you want more 'positive' shifts.
I'm running both of my bikes GP-shift pattern, because once I switched one, the pattern made more sense, so I swapped the other one as well.
Edit: Search function helped...
https://www.superhawkforum.com/forum...rs-swap-27425/
1994 VFR lever swaps on, but does reverse the shift pattern as mentioned earlier.
CruxGNZ
Jan 13, 2016 07:19 AM
Badboy01
Jul 15, 2015 11:04 PM
TJ91
Oct 11, 2013 02:37 PM
zagger1586
Jun 14, 2011 01:59 AM
Shawn Torpey
Feb 22, 2007 03:46 AM
