Very specific California carb & EVAP question with photo
Old May 25, 2014 | 01:27 AM
TboneNast's Avatar
Amateur Hour, Every Hour
TboneNast is on a distinguished road
Hi All,
After performing PAIRectomy, TPS mod, new plugs, installing OEM exhaust (goodbye 2Bros), and 8541Hawk's carb setup, I decided to rip out the CA EVAP stuff as well. It's a snarling $h!tstorm of tubes in there!
A. The two separate CA Carburetor Air Vent (CAV) and CA EVAP PURGE control valves are gone along with the EVAP canister.
B. The fuel tank breather tube was removed from the CA EVAP canister and re-routed with tank drain tube. No PVLIR issues
C. PAIR vacuum line and CA PURGE vacuum line have been capped on the front carb (see 2 black caps on front carb in photo below).
My question is for Hose #5's spot, left of photo, you can see here I've put a big cap on the tee fitting. Should that vent to air? It goes to the CA CAV Purge valve.
Based on page 1-29 & 1-32 of the manual, and using my limited knowledge of this system, it appears that the Purge control valve uses vacuum power from front carb to allow fumes from evap canister and vented fumes from hose(s) #6 to then re-inject into the air-fuel mix. If this is correct, not capping it may cause unfiltered air to get into intake system.
Please someone let me know if I am off base or just dead wrong here.
Tomorrow morning I'll finish up the "under seat sync" extension and get her running again.
Thanks for your time.
Oh and P.S. Should I use clamps in addition to the tight fitting rubber caps?
Old May 25, 2014 | 10:14 AM
They should be plugged and clamps are not really needed.
Old May 25, 2014 | 11:16 AM
TboneNast's Avatar
This is going to be a good day; I got the answer I wanted from the Grand Master of Superhawk Carbs himself!
Old Jun 2, 2014 | 11:09 PM
brettbutzer's Avatar
brettbutzer is on a distinguished road
hi..
in my opinion They should be connected and clamps are not really required.
Old Aug 13, 2022 | 05:59 AM
Originally Posted by Tortalover
Want to remove California accessories, but don't know where all the other hoses go. If you have pictures, I would appreciate it. Thanks.
Asking the same questions in 10 different threads will produce the same result. Please.... look around a bit first.
https://www.superhawkforum.com/forum...-removal-9875/
blamecanada
Dec 15, 2011 07:10 PM
20_rc51_00
May 23, 2011 08:22 PM
spladle160
Apr 14, 2010 08:32 PM
salmanilla2000
Nov 25, 2009 10:15 AM
gotbeef
Aug 2, 2005 10:37 PM
