Running hotter and using more fuel
Old Mar 31, 2013 | 02:21 PM
whatthefnck's Avatar
THE LANE CARVER
I have about 200mi after readjusting my rear cams. Seems at 80 degrees lately my bike has been running hotter than it did at peak of last summer. And seems to be drinking more fuel. Did I maybe hook up the fuel tank or something wrong?
Old Apr 1, 2013 | 12:20 AM
Might try giving your manual CCT's a little, little adjustment...
Old Apr 1, 2013 | 12:28 AM
THE LANE CARVER
Not using manuals. OEMs
Would the fact that when I reinstalled the cams I have no slack between the cam sprockets make it hotter? That wouldn't make any sense to me.
Last edited by whatthefnck; Apr 1, 2013 at 12:44 AM. Reason: Removed dumbass question "Tweety, where you located?"
Old Apr 1, 2013 | 04:19 AM
RWhisen's Avatar
Former Superchicken Owner
What do you mean "no slack between the cam sprockets"?
Old Apr 1, 2013 | 07:23 AM
THE LANE CARVER
Someone on another thread wrote he had 1/4 in slack between his cams. So I thought maybe it was pertinent to add that info. But when I checked my rear cylinder valve clearances and reassembled the cam sprockets to spec and made sure there was no slack from the intake cam to crank, and no slack between the intake and exhaust. All slack was from crank to exhaust sprocket.
Old Apr 1, 2013 | 08:29 AM
Hopefully you saw my response in your other thread, but adjusting slack is only for manual CCT's. So yours should be correct.
If you've only run one or two tanks, I'd run a couple more before being concerned about fuel usage. Sometimes you just get a tank or two that don't match.
As far as cooling, if the bike has sat for a bit, it may just need a coolant flush or new cap. Is the fan still kickin on?
Old Apr 1, 2013 | 08:48 AM
THE LANE CARVER
Yes fan works every time at 216. Bike hasn't sat without running for more than 2 weeks at a time. It has fresh coolant from 11k miles ago
Old Apr 2, 2013 | 07:07 PM
THE LANE CARVER
I'm not sure what else to check
Old Apr 2, 2013 | 08:02 PM
Do you have gas smell around the bike? Maybe you have a small leak? Could be even the petcock diaphragm..
Old Apr 2, 2013 | 08:21 PM
Could you possibly be getting used to the bike and just twisting the throttle harder?
So how hot is it actually getting? Also are you moving or sitting in traffic?
What kind of mileage are you getting?
Old Apr 2, 2013 | 08:28 PM
THE LANE CARVER
Nothing different than usual riding and conditions. It's not even hot here yet. Only thing is I reattached the fuel tank with the vacuum hose connected to the petcock but it ran like **** and I didn't go anywhere with it. Then on here I was instructed proper connection. Is it possible some gas got into vacuum line and might cause some issue?
Old Apr 2, 2013 | 08:31 PM
No it wouldn't cause an issue.
I would go through and check all the vacuum connections to make sure you didn't miss any or if it has been de-pair'ed that all the ports are plugged.
Old Apr 2, 2013 | 08:48 PM
THE LANE CARVER
De-pair'ed? I'm not familiar with that. And as far as the hoses, they're only so long and of certain sizes so its hard to miss what fitting it belongs. The lil grey vacuum seems the only one that could be confusing, as it got me. No leaking either. So I'm a lil baffled.
Old Apr 3, 2013 | 12:41 AM
cybercarl's Avatar
Is it physically getting hot IE. temp gauge rising more or is it that it smells or feels hotter. Have you put a fairing lower on recently as this sends more hot air towards the rider.
Old Apr 3, 2013 | 01:54 AM
It's also very poosible with an old and tired petcock that plugging the vaccum on the wrong port would have torn the diaphragm... So while it most likely was fine before, it's very possible it's now leaking, and causing you these symptoms... Test it by sucking on the vaccum line and see if it opens and then shuts as it's supposed too...
jonjonsocal
Oct 26, 2014 11:29 PM
jdobeckj
Apr 6, 2012 11:14 PM
Anwar
Jun 5, 2010 07:50 PM
inderocker
Jan 12, 2009 10:26 AM
call me phil
May 25, 2007 03:57 AM
