Running engine w/ fuel tank off
Old Apr 17, 2011 | 05:24 AM
  #31
D VTR RIDER's Avatar
D VTR RIDER is on a distinguished road
The method of lifting the front of the tank is a good one for certain applications, however to make it easier to remove the gas tank, cut the 2 gas lines in an accessible location i.e. approximately 10" (25cmm) from the end of the hoses and installed quick disconnects. Those 2 lines were always a pain in the *** to remove or install. Don't make the mistake I made of shortening the hoses to make up for the length of the quick disconnects, the extra length is helpful in getting your hands in there.
The next time you do a carb sync, add a T splitter to the vacuum lines going to the carbs and run 2 short lines off the T to the right side of the engine. Tie wrap them together to make a neat job. The lines are always accessible for syncing the carbs without removing anything. I simply insert fine thread screws in the end of the hoses to prevent a vacuum leak.
As for the carb sync tool, insert 2 small restrictors in the lines to smooth out the movement.
Old Apr 17, 2011 | 07:54 AM
  #32
nath981's Avatar
yeah i thank gregw for sharing this method everytime I lift the front of the tank. What a great idea. Also a good idea to cut the lines but i haven't done this myself(definitely a PIA).
I used WD40 spray tubing cut to about 2" and inserted in fish tank tubing to slow oil movement to manageable levels and after much messing around, can usually sync in minutes now. With out the restrictors, the oil moves so fast that air is introduced into the tubing creating a big PIA and delays.
whatthefnck
Apr 3, 2013 01:54 AM
kostritzer
Jun 13, 2012 10:34 AM
J Bragg
Feb 4, 2011 06:32 PM
JamieDaugherty
Aug 4, 2006 06:51 AM
ClevelandSuperhawkRumble
Apr 17, 2005 05:58 PM
