Pulling the stator
Old Jul 15, 2011 | 07:12 PM
3amta3's Avatar
Jack of all Master of non
3amta3 is on a distinguished road
Pulling the ROTOR
has anyone pulled the rotor before? if so what did you use as a puller for it? i am thinking a 3/4 inch pipe with 15 count threads, does that sound about right?
any help would be good as i am going to pull it off tomorrow some how.
Old Jul 15, 2011 | 10:39 PM
redhawk98's Avatar
redhawk98 is on a distinguished road
After you remove the cover, it is held by three bolts. Let'em loose and you're done. A no brainer.
Old Jul 16, 2011 | 05:53 AM
3amta3's Avatar
sorry i ment rotor...
Old Jul 16, 2011 | 10:27 AM
The flywheel is 22X1.5mm (I believe) not 3\4 NPT
You need to get the motion pro puller if you can't find the proper size bolt.
Old Jul 16, 2011 | 02:06 PM
3amta3's Avatar
anyone have one they want to send my way?
Old Jul 16, 2011 | 03:15 PM
geekonamotorcycle's Avatar
Are you certain your stator is your problem?
Old Jul 17, 2011 | 12:20 PM
3amta3's Avatar
it is the rotor not stator. and no that is not the problem, the problem is behind the rotor. the starter clutch and gears are the problem. i have checked everything else and it is the only thing left to look at.
Old Sep 28, 2011 | 06:32 PM
K30's Avatar
K30
K30 is on a distinguished road
Whooop. Disregard.
Sgt Rock
Apr 22, 2008 05:30 AM
radbikers
Feb 6, 2008 06:59 PM
redman
Aug 22, 2007 08:34 PM
Mick-e
Nov 5, 2006 03:35 PM
