Please help electrical problem 98 vtr 1000
Old Feb 25, 2009 | 07:34 PM
Century 21's Avatar
Century 21 is on a distinguished road
Today I was riding when I came up to the light the bike died. I got to push it for a while looking like an ***. Anyway its totally dead no lights nothing. I charged the battery thinking it might be that. Battery is fully charged now and still nothing. Any suggestions?
Old Feb 25, 2009 | 07:38 PM
98ILVTR's Avatar
Something just makes me think of the Regulator Rectifier, but I am not someone who is an expert by any means. Maybe someone else can verify for you!
Old Feb 25, 2009 | 07:45 PM
NAVY8TR's Avatar
+1 on that...any other symptoms? I too am by no means a expert on the matter but I know my R/R has gone but it isn't a consistent problem. Do your gauges periodically go out or flicker, if you're coasting down the road and then engage the clutch will the bike sometimes shut off? or is this the first time this has happened?
Old Feb 25, 2009 | 07:48 PM
Century 21's Avatar
This is the first time it has happened. I just got the bike yesterday......lucky me
Old Feb 25, 2009 | 07:52 PM
Century 21's Avatar
what is a Regulator Rectifier? what does that cost?
Old Feb 25, 2009 | 08:00 PM
HawkFanatic's Avatar
HawkFanatic is on a distinguished road
#1) Changes A/C to D/C to charge the battery
#2) About $80 used
http://www.amazon.com/2000-Honda-100.../dp/B000ZYZVIM
A lot of people will put the R/R from a Yamaha R1, apparently they are a little beefier - I still have the stock one though.
I would check on your fuses first though.
Good Luck
Old Feb 25, 2009 | 08:55 PM
nothing's Avatar
ride it out
i'd also check your 30A main fuse which is under the rear tail on the driver's left side across from the R/R
Old Feb 26, 2009 | 06:20 AM
NAVY8TR's Avatar
research all the forums on this site, you'll find a lot of good info on what you're looking for, heres something to start on...
http://vtr1000f.wickidnet.com/
Old Feb 26, 2009 | 06:31 AM
honda996's Avatar
honda996
Definitely check the main fuse first. My bike died similarly to how you describe, when I went hunting I found the main fuse blown. Investigate from there, something caused that. The culprit in my situation was the R/R being toast, I bought a new one from Rick's motorsport electrics.
Old Feb 26, 2009 | 06:41 AM
gboezio's Avatar
Test the bike voltage with a multimeter after changing that main fuse, just to make sure that the fuse did not blow from a too high tension (pushing more current trough accessories), you don't want to toast your coils and ICM
May be an intermitent short too, check the battery connections too, you may get power on the battery terminals but not on the bike
Old Feb 26, 2009 | 10:22 AM
RickB's Avatar
If you go with a stock R/R the later version with cooling fins seem to hold up much better... my '02 has the later version and I believe they came out on the '01 and later models. Good luck with it.
Old Feb 26, 2009 | 10:39 AM
you can get them off ebay for resonable, just make sure it is finned.. most Hondas of that generation use the same one:
http://cgi.ebay.com/ebaymotors/NEW-H...Q5fAccessories
Old Feb 26, 2009 | 12:55 PM
SlowHAWK's Avatar
Don't buy a used R/R.... your just asking to have it happen again.... If it was the R/R... usually you'd notice the bike slowly selectively shutting things down prior to shutting off... lights go out, tach stops working... then kaput. Your battery will be dead or damn near dead as well.
Anyway... I got mine from here...
http://www.ricksmotorsportelectrics.com/
It's a finned unit.... and haven't had an issue...
J.
BTW... I actually believe 90% of R/R failures happen within 4 weeks of a owner buy the bike... mine lasted a whole 3 weeks before I was stuck on a busy parkway with no shoulder in Sunday afternoon traffic!!!
Old Feb 26, 2009 | 01:11 PM
The one I linked to is new, and aftermarket for $49 plus $8 shipping..
Old Feb 26, 2009 | 01:17 PM
J.
+1 on not buying used. Here is another place to check out.
http://www.regulatorrectifier.com/
Old Feb 26, 2009 | 04:05 PM
thetophatflash's Avatar
Have you cleaned your cables and battery posts?
Old Feb 26, 2009 | 08:09 PM
Century 21's Avatar
I have cleaned my battery and posts. Others that I have talked to say probably not the r/r , it wouldn't have stopped all at once i would have seen surges to the lights/tach going in and out etc. so hopefully just a fuse.
Old Mar 2, 2009 | 12:03 PM
It is probably a fuse.. but it is also still likely to be the R/R too (what caused the fuse to blow) If you have a volt meter, once you get the bike running again, put it on the battery and let us know the voltage you see at idle and at 5500 rpm.
Old Oct 26, 2016 | 10:21 PM
steve74's Avatar
steve74 is on a distinguished road
that would be your regulator rectifier change it bike will be fine mine did it the ot
Mikael
Nov 11, 2014 08:04 PM
dwade71
Aug 27, 2013 02:21 PM
Gtrain00
May 27, 2010 09:33 AM
swaptrex
Jul 9, 2009 06:48 AM
Erik S.
Dec 2, 2007 01:10 PM
