Electrical Problem? Need help!!
Old May 25, 2010 | 07:14 PM
Gtrain00's Avatar
Gtrain00 is on a distinguished road
So i am riding down the street and approaching a stop sign on a beautiful summer evening and the old hawk decides to completely shut off. It happened that quick. I was riding and completely lost all power, and after the fact the bike would not turn on at all. A strange smell was coming from the tail of the bike. ( Stator??) I think the previous owner may have maybe moved the stator to the back and maybe thats what the smell was? But anyways i have no power and a weird smell,and clearly a lack of knowledge on the subject.. i know you guys know these bikes inside and out. Anyone have any knowledge that can help me??
Thanks,
Grant.
Old May 25, 2010 | 07:19 PM
peterpanic's Avatar
pragmatic anarchist
B-R/R-B-Q
Old May 25, 2010 | 07:24 PM
Gtrain00's Avatar
im sorry im not sure what that means
Old May 25, 2010 | 07:34 PM
bjorn toulouse's Avatar
Destructive Tester
The stator is under the left side engine cover, the regulator/rectifier is under the tail piece (about the middle of your right thigh when you're seated on the bike).
Remove the seat and peek between the tail piece and the sub frame.
Rex
Old May 25, 2010 | 07:41 PM
Gtrain00's Avatar
okay thanks man that makes sense.. i took off the seat and the smell was coming back there.. and i mean i am pretty sure thats all it could be is the r/r right? nothing else would make sense for it to just cut out like that and smell right in that area.
Old May 25, 2010 | 09:36 PM
it's the R/R
Old May 25, 2010 | 09:40 PM
Little_Horse's Avatar
2nd mouse gets the cheese
if the smell is like rotten eggs your battery is now toast too.
Old May 27, 2010 | 07:47 AM
stangy89's Avatar
stangy89 is on a distinguished road
You can check the stator... but it most likely the R/R if it's the finless OEM part
check the resistance between the three yellow wires on the plug it should be between 0.2 - 0.5 ohms. Check for continuity between the wires as well. There should NOT be continuity if there is or the resistance measures other than the speced ohms you should replace the stator.
Old May 27, 2010 | 08:07 AM
peterpanic's Avatar
pragmatic anarchist
Sorry. Memorial Day weekend coming up. Your R/R is probably cooked. Early models are served rare, since they were obviously not well done. Later ones (finned) a bit better. Still not too tasty.
Old May 27, 2010 | 09:33 AM
Stevebis1's Avatar
As with the other answers you will likely need a new battery and an RR. Testing these will tell for sure. Possibly it could be your battery's time was up. That just happened to me recently.
If the battery wont take a charge, replace it. Once you can start the bike you can check for abnormal voltage at the battery. Follow the instructions on this link:
http://www.electrosport.com/technica...ng-diagram.pdf
Century 21
Oct 26, 2016 10:21 PM
centar
Jul 21, 2015 10:40 PM
kraher
Jun 24, 2010 04:33 PM
dshakes
Jun 14, 2009 06:17 PM
mcbrien
Nov 12, 2007 10:26 PM
