Hot starter
Old Sep 15, 2007 | 07:33 PM
Fish's Avatar
Hot starter
When I go to start my bike it cranks over fine then slowly dies before it fires up. It has a new battery. Connections at soliniod are clean as are the battery and ground. The starter gets REAL warm. Starter hosed? R/R?
Any help?
Thanks.
Old Sep 16, 2007 | 04:41 PM
RickB's Avatar
Starter doesn't sound the happiest... it shouldn't get real warm unless you have to crank the bike a for an extended period of time (like over 30 seconds) to get it to start.
Old Sep 17, 2007 | 06:28 PM
Fish's Avatar
I took the starter off and connected it direct to the battery.....spun it up for a good 20 seconds....cool to the touch. It spins freely, no bearing or brush grabbing. Then reinstalled it and directly connected it to the battery and the battery worn down quickly. Didn't have enough juice to check the temp.
Did I get a bad "new" battery? Would a bad battery cause strain/heat? Could mice fly if they had wings and feathers?
Old Sep 17, 2007 | 09:45 PM
98greenchicken's Avatar
98greenchicken is on a distinguished road
Bad ground would be my first thought but working in parts for so many years I would not rule out that battery. You never know.
Old Sep 19, 2007 | 09:24 PM
I just had a 5 month old battery die on me. Did yours happen to be a Parts Unlimited battery? Stock replacement? Mine was. I thought it was the starter too. I was getting good voltage but there wasn't the amperage to start the bike. Have the battery tested. If your starter is shot I have another one for you for $50.
Old Sep 20, 2007 | 07:54 PM
Fish's Avatar
Going to test the battery....was thinking the same or a poor ground somewhere. I'll keep you I mind for the starter Greg. Thanks.
Old Sep 25, 2007 | 05:52 PM
Fish's Avatar
Battery had a dead cell. Problem solved.
wsharpman
Jul 4, 2012 02:31 AM
johnnyhonda
Jul 26, 2010 01:53 AM
Vincent
May 12, 2009 08:22 PM
Vega (streetfighter)
Sep 4, 2008 11:54 PM
Dave Wicks
Mar 15, 2007 05:37 AM
