Help: Vacuum Lines? Holes at back of Airbox?
Old Sep 2, 2008 | 08:57 AM
Hardhead's Avatar
Hardhead is on a distinguished road
I'm at the finishing stages of getting my SHawk on the road but I have a few things that I need to find out before I call it done. It seems the po removed a few hoses and left four small hoses 2 on each side of carbs that exit towards the rear of the carbs, loose (vacuum?). It looks like it may have something to do with emmissions that were removed. There are also 2 holes in the back, bottom side of my airbox about 1/4 in diameter that are not plugged. I don't see any diagrams in the service manual that would help. I have the four hoses plugged for the meantime til someone can point me in the right direction. The bike is running, carbs are synced, new plugs, new tps, but seems to be running a little lean not sure if it needs to be rejetted (excessive backfire through exhuast on decel) or if it's the loose hoses (both?). Bike is stock w/ baffleactomy.
Old Sep 6, 2008 | 02:27 AM
shayne's Avatar
Post up some pics.
Old Sep 6, 2008 | 05:13 AM
filter69's Avatar
Thats Mr Dill hole to you
the hoses on a non california bike after the pair has been removed properly are very sparse
the 2 that hook to the carbs are the fuel bowl vents and then the rear carb haas a vac hose the goes to the petcock then there are 2 drains that go to the red painted part of the tank and the BIG rubber hoses on the carb go to the air box ....i left out the fuel lines
since they kinda explain themsleves
Old Sep 6, 2008 | 08:48 AM
Hardhead's Avatar
I need to take some pics. I have all the hoses hooked up as you describe. From my understanding this is a California bike, it looks as though the po removed I'm guessing the evap system but left the hoses dangling. Bike is running strong but around 6k (this is hard to describe) it changes tone briefly then goes back to normal. It doesn't bog or anything like that.
HRCA#1
Jun 25, 2013 06:17 PM
VThokie412
Nov 13, 2011 11:00 PM
c-dub
Nov 25, 2009 06:16 PM
StoneJrW
Apr 30, 2007 01:48 PM
