HELP - I can't get the front cylinder crank vent hose back on the airbox
Old Nov 12, 2011 | 11:26 PM
VThokie412's Avatar
VThokie412 is on a distinguished road
I pulled the airbox to remove the pair system, which was successful. I am trying to put it all back together and for the life of me I cannot get the hose and clamp back on the airbox for the fron crank breather. Any suggestions? Is there an easier way to do this?
Old Nov 13, 2011 | 12:12 AM
That one's tricky. If it's the hose I'm thinking of... the longer "s" one and not the short strait one.
When I'm putting the airbox on, it's the first hose I attach. I attach it to the airbox along with the hose clamp, then lower the airbox onto the two short carb intakes, then attach the longer "s" hose at the rear of the airbox. Then I screw the airbox into the carbs. I can't really get it attached if I have the airbox already installed.
Old Nov 13, 2011 | 02:00 AM
VThokie412's Avatar
Well, I got it, pissed me off for about an hour but its on there, minus the pair system. Would everything be copasetic if I were to vent the crank breathers to atmosphere through small filter or a catch can? Could save alot of trouble every time you gotta take the airbox off.
Old Nov 13, 2011 | 04:35 AM
jay956's Avatar
This is the one time I'm glad to have skinny hands, still a pain to get on though.but like moore said, make that the first house you put on.
Old Nov 13, 2011 | 04:59 AM
zmaniv's Avatar
Whenever I do work with the air box off I disconnect that hose frim the head before trying to put it onto the airbox. Gives me a but more room to play with
Old Nov 13, 2011 | 09:02 AM
mboe794's Avatar
I've tried diconnecting it from the head too. Then replacing it after the airbox is on. I only did it once. To me, making that second connection aint any easier than just doing the one at the airbox. I ended up sitting on the floor with a flash light and long-*** needle nose trying to get it back on. After probably a dozen times of removing the air box I've got that top connection down pretty well. Takes a few tries, but with some patience it can be done in less than 5 minutes.
Old Nov 13, 2011 | 03:42 PM
bass4dude's Avatar
bass4dude is on a distinguished road
Hmmm, I usually don't have any problems with that particular hose nor do I have small hands, in fact, I think they're a little weird!
But what I do is put my hand through the front frame brace in front of the air box, and reach around and put that on the front nipple. It also makes it easier to attach the diaphragm air supply too!
But be cautioned, there is a veryyyyyy sharp end of a cotter pin through the throttle linkages, I had a puddle of blood underneath me before I even realized that I was bleeding....
But my carbs were on nicely
Old Nov 13, 2011 | 04:45 PM
It seems to help to lube up all involved parties with a bit of motor oil or vaseline. This way they slide right on.
Old Nov 13, 2011 | 05:13 PM
+1... a little WD-40 goes a long way.
Old Nov 13, 2011 | 05:42 PM
zmaniv's Avatar
Yea I like my hose lubed before I install it
Old Nov 13, 2011 | 09:04 PM
VThokie412's Avatar
I was thinking of extending the breather hose a few inches to make it easier to reassemle. I don't wanna deal with that every time I have to work on it.
Old Nov 13, 2011 | 09:33 PM
rfbeischer's Avatar
rfbeischer is on a distinguished road
Attach the hose to the airbox first, then lay the box in, then connect the hose to the head. This odd method worked after much trial and error, and lots of cursing.
Old Nov 13, 2011 | 11:00 PM
zmaniv's Avatar
That's what I said
I wanna go FAST!
Jul 10, 2016 05:02 PM
thedeatons
Apr 1, 2015 01:49 PM
wayne
Apr 24, 2012 07:14 AM
Hardhead
Sep 6, 2008 08:48 AM
inderocker
Jul 7, 2005 08:04 AM
