electrical problems
Old May 19, 2009 | 07:51 PM
RIHDER34's Avatar
KANKS!
RIHDER34 is on a distinguished road
electrical problems
Ok so here's my problem, ill be just riding with no problems then ill stop for a few minutes. Ill hop back on go to start it up and it wont start. Being desperate ill pop start it to go home, turn it off and let it sit. Ill go back to it ten minutes later and it will be fine. any idea's...
and no i didn't leave the key on....
Old May 19, 2009 | 09:24 PM
So does it crank but not start, or not crank enough to start? My initial thought is a bad battery.
Old May 20, 2009 | 02:51 AM
gboezio's Avatar
Connect a multimeter to the battery while it fails cranking and check if there's a voltage drop.
Old May 20, 2009 | 10:04 AM
RIHDER34's Avatar
KANKS!
When i try to start it, it will start to crank then it wont have enough juice left to start. The battery is brand new
Old May 20, 2009 | 10:40 AM
You could have a bad R/R (voltage Regulator / Rectifier) that killed your nice new battery..
Old May 20, 2009 | 03:57 PM
Circuit_Burner's Avatar
guru of things sparky
Heavy overcharging fries them out good.
Old May 20, 2009 | 05:54 PM
MOONSTER's Avatar
JUST MY 2CENTS WORTH, BUT IF BATTERY IS NEW & CHARGE IS GOOD, IT'S POSSIBLE THAT STARTER IS GOING BAD. AS WITH MOST ELECTRICAL COMPONENTS, HEAT IS AN ENEMY. AFTER RIDING ENGINE HEAT IS TRANSFERRED TO STARTER THEREFORE POSSIBLE HIGHER RESISTANCE.
Old May 20, 2009 | 06:52 PM
In my 11 years of being on mailing lists and forums in one form or another, I've only heard of one starter failing on a Superhawk. Granted, it's possible, but highly unlikely. A defective battery is quite possible. I had one go bad after 2 months. Voltage will be good but amperage will suck *****. BTDT
Old May 20, 2009 | 07:47 PM
MOONSTER's Avatar
Hey Hawkrider, not disputing what your saying. Just mentioning as a possible problem. Not even sure what yr. his bike is. I can only relate to my experience in my line of work which is generator repair. If he had access to a battery load tester that would prove if the battery was dropping under load. I also concur that just because battery voltage reads good, doesn't mean battery is, the true test is when load is applied.
Old May 21, 2009 | 09:01 PM
RIHDER34's Avatar
KANKS!
THANKS HAWKRIDER! i took your advice even tho i honestly didnt think it was a bad battery, but it was, cheap Chinese crap. thanks eveyone for your help
-dave
Old May 22, 2009 | 02:50 AM
Glad you got it figured out.
It'd probably be worth the extra 5 min to test that your R/R is not overcharging the system to be sure that you won't be killing another battery soon.
Old May 22, 2009 | 09:25 AM
Hot, Gooey batteries dont last long.
Old May 22, 2009 | 09:28 AM
Syclone's Avatar
Boosted
+1 on checking your R/R, 5 mins of testing could save you much more time and $
ride_hard
Jul 3, 2013 09:33 AM
jay956
Mar 6, 2011 02:27 AM
Ryder3610
Nov 21, 2010 12:08 PM
nevinreilly
Jun 10, 2008 05:08 AM
StoneJrW
Feb 1, 2008 02:11 PM
