Clutch Issue
Old Sep 7, 2020 | 06:39 AM
nnjhawk02's Avatar
Clutch Issue
So my 02 with 67k, has had some slippage over the past 2 years and Saturday I rode to work & then upstate NY.
Well clutch isn't working, barely can get into neutral when at stop light and downshifting very difficult.
I'm thinking the plates are toast but saw some posts about clutch master cylinder
This is the original clutch.
Was going to change the plates and springs & gasket - is there anything else that I need to change?
Other than a torque wrench do I need any special tools?
Lastly where should I order from?
Thanks
Old Sep 7, 2020 | 08:28 AM
ascothawk's Avatar
ascothawk is on a distinguished road
Clutch issues
I order my parts from Service Honda in Hammond Indiana. They have an easy site to search from and great prices. I prefer oem friction discs and plates. And replace the springs,they are cheap. I use Barnett springs they are only about 10% stiffer than oem. The trouble your having shifting sounds like the clutch not disengaging fully,the time I had a slipping clutch on my Hawk was caused by weak springs. I replaced the discs and plates that showed no measurable wear or
glazing and still had a slipping clutch under load. Then I went back in and replaced the springs.Problem solved.
Old Sep 7, 2020 | 09:48 AM
I'd make sure that master and slave cylinder are clean/not full of gunk and properly working. How often have you bled the system w/ fresh fluid? 67k isn't bad from a clutch. EBC makes a great replacement kit, check out the SRK. Pick your favorite vendor:
https://www.sportbiketrackgear.com/e...es-clutch-kit/
https://www.ebay.com/itm/HONDA-VTR10...oAAMXQMXRQ6uQ-
Barnett isn't a bad name either. OEM is always great but in this case, I'd do an EBC. I've put them in many bikes at the shop. Great quality, little stiffer springs yadda yadda.
Here's what my slave looked like a few years ago when I rebuilt it.
And all the parts I replaced:
Been a looong time since we've chatted! Hope all is well.
Old Sep 7, 2020 | 08:17 PM
Cadbury64's Avatar
VTR virgin
The symptoms sound a whole lot more like air in the clutch line than a worn clutch. In the first instance I would be cleaning out the hydraulic circuit and pistons and refreshing the fluid, and then putting in new seals if needed. I recently swapped out the seals in my slave cylinder as it had developed a weep, and have previously inspected the clutch discs but they were in great shape at nearly 90,000km.
Old Sep 8, 2020 | 09:57 AM
nnjhawk02's Avatar
Thanks everyone - I have new fluid in there from - either this Spring or last year - I change all brake & clutch fluid every two years & use syn.
As stated, I've noticed slippage over the last year or 2.
Some pics from trip in June with son on his R6. Rode secondary roads from Lehigh Valley Pa to WVa & Va. Great trip - Rt. 33 in WVa is awesome. Was by Germany Valley and Second pic is the infamous Smoke Hole Rd in WVa. - Top Case & Dry Bag strapped behind me & I can travel anywhere.
Old Sep 8, 2020 | 06:30 PM
Looks like quality time!
If you're confident in the hyro's, Get yourself a clutch kit and slap it in there. It's easy to do.
Old Sep 9, 2020 | 07:32 AM
I’ll throw this out there as another possibility. Do you have after market levers? Some have been known to apply pressure to the master when not pulled.
More likely what has been previously suggested, but....
Old Sep 9, 2020 | 07:06 PM
nnjhawk02's Avatar
Thanks - in fact I do.
I installed Pazzo adjustable levers after I destroyed both on a trip 2 or 3 yrs ago
Old Sep 10, 2020 | 04:27 AM
CrankenFine's Avatar
Especially if not installed correctly... as I learned a few years ago.
Old Sep 17, 2020 | 03:12 PM
ACE VenTRa's Avatar
The first thing you should do is just pull the clutch plates out and measure them. Check the steels for overheating or wear, If they are in spec just change the springs and reinstall. If that doesn't fix it, change the slave.
AV
Old Mar 23, 2021 | 12:00 PM
nnjhawk02's Avatar
Finally uncovered the VTR to troubleshoot clutch not engaging
No fluid & Slave looks like it sprung a leak.
Just ordered the Oberon in Red - the fastest color - so they said
Old Mar 24, 2021 | 06:20 AM
No surprise there. The O will fix you up fine.
Old Mar 30, 2021 | 01:26 PM
nnjhawk02's Avatar
All Good now - Got new one from Oberon Performance in the UK - easy & quickly shipped. Rec'd yesterday & just finished install.
not too difficult to do - PITA was getting old paper gasket off.
Yuckies
Oberon - All Good now!
Old Mar 30, 2021 | 03:21 PM
I use this at the shop, it’s awesome.
Too late for you but if you have any jobs in the future, it’s worth buy-in.
Old Apr 26, 2021 | 02:44 AM
CJVTR00's Avatar
CJVTR00 is on a distinguished road
Yuckies
Did you get a can of degreaser as well?
Old May 2, 2021 | 09:57 AM
nnjhawk02's Avatar
? from Oberon?
No - I did clean out the junk from inside & flushed out with new synthetic
executioner
Nov 6, 2018 02:28 AM
Shappy1
Apr 14, 2016 07:01 AM
FL02SupaHawk996
Aug 9, 2010 12:56 PM
RoofCleanPhenom
Apr 22, 2008 06:05 PM
jakeeboy
Oct 31, 2006 06:24 PM
