charge question..
Old Jun 27, 2020 | 05:08 AM
swe-jonke's Avatar
swe-jonke is on a distinguished road
charge question..
hi!
I have issues with my vtr, it drains the battery in a short while. im sure that the battery is wearnout. My ctek charger tells its broken.
I have a new battery, but i havent installed yet, whant to make sure nothing else is broken in the bike. my bike i vtr1000f -98.
I have mesured charge and im a bit worried, is this ok ?
On idle (1300 rpm) it charges 14,8.
other she charges 14,3-14,4.
If i charge the battery, i can start her and drive, but somethimes she's missfire and stops. If i charge battery she for 24 hrs she works again.
I know battery is broken, how about the r/r?
Is it normal that shes charge 14,8v at idle?
im from Sweden, english isnt my first language... Pardon for my spelling...
Old Jun 27, 2020 | 08:38 AM
What is the battery voltage engine off? Take a look at the connector (wires coming from the R/R i.e. regulator/rectifier) under the seat at the back of the tank. It's inside the plastic sleeve. Is it discolored or melted? Also take a reading of battery voltage as the engine is started.
Could be the battery is weak, not holding a charge. Has the stock R/R been replaced?
Old Jun 27, 2020 | 09:13 AM
swe-jonke's Avatar
I changed the r/r and battery last year (cheap battery from "Biltema" and shindegen non mosfet r/r. I will check the wires and connectors... Feels like i whant an mosfet r/r...
Old Jun 27, 2020 | 09:31 AM
Wicky's Avatar
Download the Bike battery charging problems troubleshooting guide from https://www.electrexworld.co.uk/acatalog/Technical.html
Also get the PDF Factory service manual which specs the charging system.
Get the old battery load tested / fit the new battery and run the tests - Getting a Mosfet R/R will certainly help give better reliability to the bike.
Old Jun 28, 2020 | 07:06 AM
swe-jonke's Avatar
i checked my r/r i have in the bike, modell name is sh633-12. It have colling fins.
Old Jun 28, 2020 | 07:24 AM
While better than the stock unit, it is still a series type R/R. Do the load test on the battery to eliminate that variable.
Old Jun 29, 2020 | 04:43 AM
https://www.superhawkforum.com/forum...53-00-a-34792/
99Hawkboy
Sep 4, 2012 09:29 AM
turbotim
Jun 1, 2010 02:21 PM
evines
Apr 25, 2010 12:24 PM
glock221
Apr 12, 2010 09:03 AM
offroad_rider2008
Feb 4, 2010 04:01 AM
