R/R or Battery
Old Apr 12, 2010 | 08:57 AM
glock221's Avatar
glock221 is on a distinguished road
R/R or Battery
OK I am a mechanical dummy. With that said, I have been riding my bike for the last few weeks with no issues. I parked it yesterday and tried to start it today, and it acts like the battery is dead. it tries to turn over then just clicks like a dead battery. The lights seem to be on when the key is on. I can jump start it with my battery booster and it will start. I measured the voltage on the battery and it is at 11.75 with the bike turned off. Any ideas?
Old Apr 12, 2010 | 09:03 AM
Little_Horse's Avatar
2nd mouse gets the cheese
Basic test to be able to tell would be to fully charge the battery with a tender or charger, remove it wait over night then check the voltage on the battery if it has dropped then replace the battery. Checking the R/r is more tricky since it does two things limits voltage and changes AC current to DC current if one system fails the battery will not be charged after using the bike, so the other test (which can leave you stranded) is to charge the battery drive the bike park it then check the volts at the battery if it lower then 12volts the R/r is suspect.
phillip
Jan 14, 2008 11:13 AM
fundgh
Apr 20, 2007 11:38 AM
Otto Man
Feb 2, 2007 12:57 PM
Hawkrider
Jan 1, 2007 04:20 PM
Corona Hawk
Nov 8, 2006 04:19 AM
