bafflectomy help!
Old Jun 6, 2009 | 04:10 PM
merlyn's Avatar
merlyn is on a distinguished road
bafflectomy help!
I drilled 4 holles in each baffle wall and now the sound is great! The problem is...my bike runs hotter?WTF?
Old Jun 6, 2009 | 04:24 PM
Circuit_Burner's Avatar
guru of things sparky
Are the holes going thru the outside of the can? lol
Old Jun 6, 2009 | 05:18 PM
Syclone's Avatar
Boosted
I find it hard to believe that an increase in heat is related to free-er flowing exhaust.
Old Jun 6, 2009 | 05:49 PM
Fozzy Bear's Avatar
Fozzy Bear is on a distinguished road
Technically, the engine would be running a bit leaner and thus a bit hotter but I removed the rear baffles completely from my stock cans before I got the Jardines and there was no perceivable increase in engine temps.
Old Jun 6, 2009 | 11:05 PM
merlyn's Avatar
the holes are are inside of the cans...
Old Jun 7, 2009 | 12:09 AM
That means if you richened the jetting to whatever it wants, you gain Horsepower.
Not so bad.
Old Jun 7, 2009 | 02:32 AM
merlyn's Avatar
could be this a problem...the heat?should I rejjet the carbs to get rid of this>???
Old Jun 7, 2009 | 05:48 PM
Syclone's Avatar
Boosted
This bike doesn't necessarily need a re-jet for exhaust, and unless you pulled all of the guts out of the stock pipes, I really doubt you leaned up the engine enough to cause a temperature spike.
Old Jun 7, 2009 | 10:31 PM
Who knows if the jetting was even in the ball-park to begin with ?
Bring a bike from colorado to texas and it will run lean as hell.
when an engine is too lean, adding fuel( richening ) will bring up the horse power and lower the combustion temp.
Add an aftermarket exhaust and this same thing is what will happen.
Old Jun 10, 2009 | 05:22 PM
Not to sound obvious, but it's summer. The farther you get into June the hotter the bike will run - yes, even in Romania. You're about the same latitude as US and in the northern hemisphere.
Old Jun 10, 2009 | 11:57 PM
merlyn's Avatar
thanks
superdave
Jun 16, 2024 06:19 PM
itsjason13
Jul 31, 2006 04:04 PM
bluevtr
Jun 12, 2006 12:03 PM
mtmansl
May 26, 2006 06:20 AM
MarkCoburn
May 18, 2006 10:59 PM
