SH847 Series R/R
Old Jul 27, 2016 | 07:28 PM
SH847 Series R/R
And its here
OEM for a Suzuki 2015 DL1000 SH847 Series R/R PN 32800-31J00
Install tomorrow
For Sale Superhawk Mosfet Kit FH020AA
Attached Thumbnails SH847 Series R/R-img_6002.jpg
Old Jul 28, 2016 | 10:18 AM
Closer
Another Amazon deliver, another step closer to install
Attached Thumbnails SH847 Series R/R-50-amp-braker.jpg
Old Jul 28, 2016 | 02:27 PM
Pulled the cowl off and removed the FH020AA, man, this new SH847 is a monster..
Not going to get it to fit under the cowl as I had hoped
And found a unpleasant surprize
Nothing some nice new yellow, 12 AWG 37/28 stranding, Tinned copper conductor, Tefzel insulation, -50° to +150° C temperature rated
Tefzel insulated wire is in particular outstanding for it's resistance to oil, oxidation, heat, sunlight and flame; and also it's ability to remain flexible at low temperature. They have excellent resistance to ozone, water, alcohol, gasoline, acids, alkalis, aromatic hydrocarbons and solvents.
in a new Furukawa QLW-F-300 socket with silicone seal cant fix
Attached Thumbnails SH847 Series R/R-correded-wire.jpg   SH847 Series R/R-all-better.jpg
Old Jul 28, 2016 | 05:29 PM
Well maybe it'll fit..... just maybe... with a bit of trimming.
But it is bigger for sure
The fins JUUUUUUst interfere with the curved lower inside of the cowl, I'll have to trim just a bit.
Always fun to take a cutting tool to a brand new $160 electronic part
Attached Thumbnails SH847 Series R/R-bigger.jpg   SH847 Series R/R-well-might-fit.jpg
Old Jul 28, 2016 | 05:49 PM
Ok so with some mods it fits under the cowl
New mounting bolts had to be welded on as the FH020 were too close together
Attached Thumbnails SH847 Series R/R-image.jpeg
Old Jul 29, 2016 | 12:39 PM
Rock solid 14.7v
Perfect for keeping a lithium ion battery charged.
End of the day is a Series style MOFSET RR better than the shunt style MOFSET FH020AA RR that is proven to work on this bike?? probably not..
But my brother just bought a 2000 superhawk and the previous owner a dealer "technician" replaced a failed regulator, with a newer fined style OEM diode regulator which of course failed in short order because this "technician" used crappy auto store crimp spade connectors and plier type crimpers which quickly overheated, melting the wire and shorting out the new regulator.
So I built a plug-and-play wiring harness for the FH020 regulator I had on my bike and sent him an entire package ready to bolt on having to only solder and heatshrink tube three yellow stator wires.
Leaving me the need for a new RR.... Hey why not try the new SH875 or buy a Superhawk Mosfet Kit FH020AA
Attached Thumbnails SH847 Series R/R-14vplus.jpg   SH847 Series R/R-pablo.jpg
Old Jul 31, 2016 | 08:10 PM
Been running this same unit since the start of the year (after doing some research). What I like is that it's series (or so I have read), which means that it only draws the current it needs from the stator (rather than pulling max from stator and dissipating the excess), meaning the stator runs cooler (should last longer) and reduces parasitic drag on engine.
Old Aug 1, 2016 | 06:10 AM
Good to hear.. I new I was far from the first to swap an SH875 in, as I have been reading reports for more than a year now while the supply stabilized. With no "need" for a new Reg I was not pushing for the new one to see how they worked.
Once the NEED came up the decision was easy .
The Shindengen company site calls it a series type RR
ƒJƒ^ƒƒO”Ì”„b“d‘•»•ib»•iî•ñbV“dŒ³H‹ÆŠ”Ž®‰ï ŽÐ
So pretty confident that it what it is.
I'll do some testing later next month and see if I can "see" the AC voltage effected or the DC voltage "shut off"
Old Jul 12, 2017 | 03:55 PM
So we are at almost a year now and figured I'd report back on all the issues this SH847 series RR has caused.
And done.....
Rock solid voltage @14.7v
Li battery staying charged (something weak charging systems do not do)
No heat issues from the new unit (it sits mere MM from the cowl,,,I half expected it to melt the cowl.
Old Jul 19, 2017 | 09:48 AM
And done.....
my experience is the same. I have an LED voltage monitor and it's always in the green (even at idle)...
Old Mar 1, 2020 | 01:50 PM
In the quest to spend more money on "upgrades" that are not really needed, I replaced a perfectly fine Shindengen FH RR with a SH847 series RR.
They are quite a bit bigger. I might have to remake the mounting plate to move the RR down and back a bit.
Old Mar 2, 2020 | 01:58 PM
Im very happy with my install some years later.. gently shaving just a few mm on the lower side of 5 fins allowed the SH847 to fit under the plastic with no fitment issues.
Old Mar 2, 2020 | 02:00 PM
Wait, I get it, you shaved yours on the top side, i missed that ,was not where I was looking for the MOD
Nice mounting plate though.
I cheated and just welded studs onto the steel subframe to position it where I wanted
Old Mar 2, 2020 | 04:26 PM
Yes, I had to trim the top side to get a small amount of clearance to the rear cowl. Grinding on a new $170 part seemed a bit silly. Would have been better a little lower and back, tighter against the stock under tray.
I see what must be a tail tidy on yours. I don't know if that gave you more space to mount a little lower.
swordfish
Sep 30, 2009 05:17 PM
swordfish
Sep 3, 2009 01:58 PM
Wolverine
Jul 31, 2008 06:30 PM
gboezio
Sep 12, 2007 04:32 PM
Gerrit
May 25, 2006 10:43 PM
