Rear stand spools?
Old Aug 2, 2006 | 08:20 PM
selztoad's Avatar
Rear stand spools?
I am not seeing a place for rearstand spools...am i missing something?
Old Aug 2, 2006 | 08:33 PM
Nope. Well, yup, you're missing the place to mount them. The Superhawk doesn't have them. Most folks use a rear stand with pads. Some have used ingenuity and had some mounts welded on.
Old Aug 2, 2006 | 08:39 PM
marmaladedad's Avatar
Hmm?
It's fairly easy to have them welded on. Just buy the PitBull spool adapters, get them welded (or DIY, if you've the experience), and you're done!
Old Aug 2, 2006 | 08:46 PM
jschmidt's Avatar
jschmidt
I don't see the point. Unless you're racing you're bike won't spend enough time on stands to justify doing a mod for it.
Old Aug 2, 2006 | 09:41 PM
superbling's Avatar
How about a tiny one car garage or having to share the same reserved parking spot with your car?
Old Aug 2, 2006 | 10:07 PM
Hmm?
Actually, for that, I use a Baxley chock. It's easy to roll onto and it makes lifting the bike up to work on the chain/rear wheel a breeze (no balancing, then sliding the stand underneath, then balancing, then lifting...).
If you stick with the stands with pads, try putting something on the bottom side of the swingarm to keep the pads from sliding (mine slid all the way to the engine before I had spools).
bikerpipes
Jun 3, 2012 10:08 AM
cmcconkey
May 4, 2008 06:59 AM
Yardstick
Jun 18, 2006 11:46 AM
NOrrTH
Nov 17, 2005 07:47 PM
ReTodd
Mar 24, 2005 01:18 PM
