Rear axle spools
Old Jun 2, 2012 | 01:20 PM
bikerpipes's Avatar
bikerpipes is on a distinguished road
Rear axle spools
Does anyone here use axle spools the ones that just slip into axle holes while using rear stand to clean chain.
Old Jun 2, 2012 | 03:32 PM
CrankenFine's Avatar
I just slide a 5/16" steel rod about 24" long thru the hollow axle.
If this works for you too, mark the ends with a bright color so you don't forget to take it out when you're done.
Old Jun 2, 2012 | 03:46 PM
bikerpipes's Avatar
Spools
Thanks that will be good enough for cleaning chain.
Old Jun 3, 2012 | 10:08 AM
bikerpipes's Avatar
Spools
I tried the rod didn't work my stand to short to lift tire off ground.
MUHerdFan
May 18, 2009 09:58 PM
shelcon
Sep 24, 2007 10:19 AM
vtrlvr
Sep 9, 2007 07:18 AM
selztoad
Aug 2, 2006 10:07 PM
Brian A
Apr 26, 2006 05:43 PM
