Wiring location?
Old Oct 30, 2017 | 06:05 PM
Floyd's Avatar
Wiring location?
Had the seat off and saw these bits floating around not mounted to ANYTHING. They are just flopped up there.
Where in the heck should these mount to?
Attached Thumbnails Wiring location?-20171030_170807.jpg   Wiring location?-20171030_170838.jpg
Old Oct 31, 2017 | 02:06 AM
Wicky's Avatar
Should be rubber mounted and secure
https://www.bike-parts-honda.com/pie...IRE+STORM.html
Old Oct 31, 2017 | 05:27 AM
The slots on the rubber surrounding piece have corresponding male plastic "posts" to slide in to keep them secure.
Old Oct 31, 2017 | 07:55 AM
By stacking one on the other, partial under the support for the seat lock.
As a quick preventative maintenance hack, you should clean the wires where they enter the weather pack plug and coat the wire(s) where the insulation is worn away with some liquid electrical tape.
Old Oct 31, 2017 | 07:59 AM
Old Oct 31, 2017 | 08:00 AM
Floyd's Avatar
Can someone take a second and post a picture of where they go? I see no posts that the rubber can slide into.
Im sure its messed up from the PO when he hacked the back and installed LED bulbs. Its a butcher job for sure. Ill take pics.
Old Oct 31, 2017 | 08:01 AM
Floyd's Avatar
Thanks Marquez! Ill take a look deeper tonight.
Old Oct 31, 2017 | 08:02 AM
VTRDarren's Avatar
VTRDarren
Random suggestion in case you no longer have mounting tabs. Two small holes drilled into the plastic undertray, then a long zip tie (or two) fed through the rubber slots to secure them.
Old Oct 31, 2017 | 08:08 AM
Old Oct 31, 2017 | 08:11 AM
I did, and just added another pic.
NOTE, folks sometimes trim (AKA Hack) up the under tail.....those plastic tabs may be gone. If so, get some Zip tie mounts from your good local hardware store or order on line.....I buy um 1000 at a time on line for pennies a piece.
Clean an area with rubbing alcohol, and stick the zip tie mounts to the plastic tray, then zip tie the ECU and converter in place.
Old Oct 31, 2017 | 08:24 AM
VTRDarren's Avatar
VTRDarren
ZIP Tie mounts?!?! I had no idea those existed! Waaay better option than drilling little holes. Nice!
Old Oct 31, 2017 | 11:22 AM
Floyd's Avatar
I also have tons of those zip tie mounts.
Stay tuned for pics tonight of the carnage!
Old Oct 31, 2017 | 03:04 PM
I also have tons of those zip tie mounts.!
At one ton, a very rough calculation says that you have ~896000 of them. Can you spare a pound?
Old Oct 31, 2017 | 03:52 PM
Floyd's Avatar
Here are a couple pre-clean up.
I have both "posts" for the boxes to mount to so ill try that route.
First trick or treating with the kids then maybe work on that tonight.
Attached Thumbnails Wiring location?-20171031_173000.jpg   Wiring location?-20171031_173035.jpg
Old Oct 31, 2017 | 08:31 PM
Floyd's Avatar
Well taking my kids out took its toll and I didnt get much done.
I did find out that the tail light bulbs are LED and were wired wrong, they now work great.
Also I cannot get the stuff onto the plastic tabs because of the bolts used for the license plate bracket hitting.
Anyone have a link for an LED flasher relay that will work with the hawk? Mine flash like they are freaking the hell out.
Old Nov 1, 2017 | 08:04 PM
Cadbury64's Avatar
VTR virgin
I have one of these on my ST1100, will also be plug and play on your VTR. Don't worry that the original flasher unit uses 3 pins and these only have two, the missing one is a ground and not actually needed. The connector size is identical.
https://www.customled.com/products/e...-flasher-relay
Old Nov 1, 2017 | 08:13 PM
Floyd's Avatar
That will fix one issue!
I have to get the tank off the bike and see what is going on under there with the fuel lines/air box and carbs.
ranchomice
Jan 21, 2010 01:51 PM
supermatt996
Apr 23, 2009 09:18 PM
jserio
Aug 7, 2008 12:16 AM
iamanonymous
Feb 25, 2007 06:33 PM
Brian A
Apr 26, 2006 05:43 PM
