Wiring location?
2 Attachment(s)
Had the seat off and saw these bits floating around not mounted to ANYTHING. They are just flopped up there.
Where in the heck should these mount to? |
The slots on the rubber surrounding piece have corresponding male plastic "posts" to slide in to keep them secure.
(Post 404410)
As a quick preventative maintenance hack, you should clean the wires where they enter the weather pack plug and coat the wire(s) where the insulation is worn away with some liquid electrical tape. |
Can someone take a second and post a picture of where they go? I see no posts that the rubber can slide into.
Im sure its messed up from the PO when he hacked the back and installed LED bulbs. Its a butcher job for sure. Ill take pics. |
Thanks Marquez! Ill take a look deeper tonight.
Originally Posted by Floyd
(Post 404415)
(Post 404415)
Im sure its messed up from the PO when he hacked the back and installed LED bulbs. Its a butcher job for sure. Ill take pics. NOTE, folks sometimes trim (AKA Hack) up the under tail.....those plastic tabs may be gone. If so, get some Zip tie mounts from your good local hardware store or order on line.....I buy um 1000 at a time on line for pennies a piece. https://cimg1.ibsrv.net/gimg/www.sup...03facb19fd.jpg Clean an area with rubbing alcohol, and stick the zip tie mounts to the plastic tray, then zip tie the ECU and converter in place. |
(Post 404419)
I did, and just added another pic.
I also have tons of those zip tie mounts.
Stay tuned for pics tonight of the carnage! |
(Post 404421)
I also have tons of those zip tie mounts.!
2 Attachment(s)
Here are a couple pre-clean up.
I have both "posts" for the boxes to mount to so ill try that route. First trick or treating with the kids then maybe work on that tonight. |
Well taking my kids out took its toll and I didnt get much done.
I did find out that the tail light bulbs are LED and were wired wrong, they now work great. Also I cannot get the stuff onto the plastic tabs because of the bolts used for the license plate bracket hitting. Anyone have a link for an LED flasher relay that will work with the hawk? Mine flash like they are freaking the hell out. |
I have one of these on my ST1100, will also be plug and play on your VTR. Don't worry that the original flasher unit uses 3 pins and these only have two, the missing one is a ground and not actually needed. The connector size is identical.
https://www.customled.com/products/e...-flasher-relay |
That will fix one issue!
I have to get the tank off the bike and see what is going on under there with the fuel lines/air box and carbs. |
