Old Mar 18, 2012 | 07:03 AM
  #121
Galaxieman's Avatar
Galaxieman is an unknown quantity at this point
Today I'll be reinstalling the lower fairing as the new paint from last week has had time to dry. My wife mentioned she has problems picking it out at the track, so now the upper and lower fairings are neon green with a black front fender, tank, and tailsection. Between that and the yellow amateur number plates, it won't win any fashion awards, but she better damn well be able to see me coming!
Old Mar 18, 2012 | 09:35 AM
  #122
zxbud's Avatar
Shim?
Originally Posted by NVDutchie
Due to our - minus temps not much really .. made a list of things I need , CCT's , Rubber, Chain/Sprockets
Oh ya , my last ride in October 2011 had to cut it short and park it .. WHY you ask ?
motor made this crazy-*** sound .. like some hammer bashing metal fabber !!
I'm pretty sure the shim "popped" out of the rear cylinder
Ok, where's that shim now?
Old Mar 18, 2012 | 10:02 PM
  #123
GlockPointer's Avatar
Connie Demico does toad?
Welcome Griffo!
Old Mar 19, 2012 | 08:38 PM
  #124
ddavi280's Avatar
ddavi280 is on a distinguished road
Called to see if my shocks were done. Nope; tomorrow
Old Mar 23, 2012 | 12:45 PM
  #125
ddavi280's Avatar
Going to start the APE CCT install and put the fresh front shocks back on.
Old Mar 23, 2012 | 05:49 PM
  #126
Griffo's Avatar
Griffo is on a distinguished road
Went for a ride up Mt Glorious near home again , bit of a Friday regular thing for me
Old Mar 23, 2012 | 08:56 PM
  #127
George H Hill's Avatar
George H Hill is on a distinguished road
First day I owned it... put on 220 miles.
Second day... 58 miles.
Tomorrow?
Old Mar 24, 2012 | 06:30 PM
  #128
Spoot's Avatar
über-n00b
Spoot is on a distinguished road
In the last couple weeks....
Mounted fairing stay, gauges, R6 master cyl, traced out wiring to make sure everything was there, installed front braided lines, bled them.
Moved the entire F4i front end from my F3 to the new-2-me SH. Converted to All Ballz taper bearings in the process.
Bled rear brake line. Looked like it was maybe flushed once in it's whole life...dirty, light brown.
Bled clutch - PO's never ever changed this fluid! It was dirty brown and then there was a skummy residue on the bottom of the resevoir. yuk. had to flush 1/4 bottle of RBF600 through the line before it started to look better/good'er. Used paper towel to wipe out the resevoir. (see pics)
Replaced the gasket on the clutch slave.
Mounted the rims with new sticky-buns!
Discovered that the superbike bars that I mounted to the F4i front end was mounted crooked. :dunce: SOooo...I ordered a set of Woodcraft clip-ons with a 2" rise.
Ordered some stickers.
Installed fork sliders that I just got from Hong Kong. Not too bad...had to de-bur the axle bolt they included so it would screw in smoothly.
To Do: install Jamie D shock - paint/mount upper race fairing and tail - change to Repsol Synth oil - change to KN oil filter - flush coolant & change to Engine Ice - safety wire a few things - source an enclosed race lower - install CCTs - convert to new reg/rec.
Attached Thumbnails What did you do with your SuperHawk today?-buns.jpg   What did you do with your SuperHawk today?-clutch1.jpg   What did you do with your SuperHawk today?-clutch2.jpg
Old Mar 24, 2012 | 06:37 PM
  #129
RWhisen's Avatar
Former Superchicken Owner
Brought her out of hibernation, lubed the chain, changed the license plate, replaced LED license plate light, got a current state inspection and a tank full of fresh gas plus rode 100 miles. Tomorrow I will get an early start!
Need to change fluids including fork oil.
Old Mar 24, 2012 | 10:44 PM
  #130
Discovered some hanging wires that could rub and get worn through... a little ziptie action and some black electrical tape to sort that out. Potential problem resolved.
Rode 50 miles.
Now I'm pondering what oil filter I'm going to use when I change the oil in her next week.
Old Mar 25, 2012 | 02:47 PM
  #131
ddavi280's Avatar
Removed PAIR valving and hoses, ordered PAIR block off plates, fuel bowl gaskets, and a vacuum line fitting for front cylinder. Replaced old cracked Stator cover with new one.
Old Mar 25, 2012 | 08:16 PM
  #132
rz_racer_69's Avatar
Old and dangerous
Took it out to play. Ride down 51 to Walnut Springs - Google Maps
Old Mar 25, 2012 | 10:18 PM
  #133
I installed a hot Guatamalan chick on the back and cruised.
Old Mar 26, 2012 | 07:42 PM
  #134
Wheelies... just a couple... and a touch of a burnoff... just for a moment of fun. I am such a child.
I do a 40 mile a day commute to work, but added another 9 because I took the long way home. I never took the long way home on the old bike.
Old Mar 26, 2012 | 09:59 PM
  #135
Hopey's Avatar
Hopey is on a distinguished road
Changed her oil ,switched to rotella !Got a 5 gallon jug ,should be good for a while.
Old Mar 28, 2012 | 10:20 PM
  #136
Touched 130. Hit a bird. (Not at 130) 55 Miles.
Old Mar 28, 2012 | 11:34 PM
  #137
Naked'98's Avatar
Naked'98 is on a distinguished road
Pulled a wheelie while merging onto/ changing lanes on I5 (oops!) then took her for a ride down Chuckanut drive between classes.
chuckanut dr - Google Maps
Old Mar 29, 2012 | 07:06 AM
  #138
Old and dangerous
Took 'er to Bikenight at the Texas House of Motorcycles and ran'er on the dyno!
https://www.superhawkforum.com/forum...no-runs-27910/
Old Mar 29, 2012 | 08:15 AM
  #139
David Alan Wilson's Avatar
David Alan Wilson is on a distinguished road
I did nothing with mine today because I do not actually own it yet. Heading to Edmonton tomorrow to finish paying for it and to pick it up. I will post some pics once I have it.
Probably will not be riding for a while since I tapped myself out financially just buying it and I think I am going to have to pay off a couple of tickets in addition to plate costs and insurance.
Old Mar 29, 2012 | 09:35 PM
  #140
Changed her oil... Mobil One Racing 4T 10w-40 Synthetic. Cleaned her up, pulling out feathers, meat, bone and blood from the bird strike yesterday. After her bath, I polished her up and lubed the chain, then took her for a ride. Found some nice twisties and practiced cornering to fix my cruiser bad habits.
46 miles added. She's purring.
Old Mar 30, 2012 | 09:07 AM
  #141
Pics or it didn't happen.
Old Mar 30, 2012 | 12:23 PM
  #142
COLE's Avatar
Crash
I recieved my new headlight from omnia racing out of italy today. I going standard. So tonight I ll be installing headlight, hiding all of wires, and putting trail tech vapor display on it. Maybe I ll finish it all in one night. And ebay shopping for a shorty can I can put on it.
Old Mar 30, 2012 | 12:26 PM
  #143
COLE's Avatar
Crash
Originally Posted by WAYNEHAMMER
Got it started after 3 years. Won't run without the choke on and is backfiring like hell. But I'm happy it's running. I'll have to tune it up or something.
How's cooling with radiators painted black? I turning my hawk to standard and haven't really road it since started project except 8 miles to work and back.
Old Mar 30, 2012 | 03:20 PM
  #144
ddavi280's Avatar
Installed set of PAIRS block off plates, new Iridiums, and starting to put front end back together.
Old Mar 30, 2012 | 04:41 PM
  #145
RWhisen's Avatar
Originally Posted by theosagekid
.....Question: how many teeth do I drop off the rear sprocket to get my rpm down around 35-3600 @ 75mph?
Currently, at 4000rpm I'm indicating just under 75, and I've seldom done better than 30mpg at that speed. I'd like a teeny bit of "no-brainer" improvement in fuel consumption.
Down two minimum in the rear, see where it puts you.
Once that's done, what do I do to solve the fact that I will have screwed up my speedo readings along with the sprocket change.
I've heard of "speedo healers."
Yes they work,
Speedohealer,Speedo Healer,Speedohealer v4, Speedo Healer Kits, Healtech Electronics, ToBeFast.com
So many questions, so little brain......
Old Mar 30, 2012 | 06:11 PM
  #146
Here she is on the CT110, I hope it's not too many points off, she had just dismounted from the Hawk.
Attached Thumbnails What did you do with your SuperHawk today?-dscn1013-400.jpg   What did you do with your SuperHawk today?-dscn1014-400.jpg
Old Mar 30, 2012 | 06:37 PM
  #147
Old and dangerous
Nice!
Old Mar 31, 2012 | 04:30 PM
  #148
ddavi280's Avatar
Front end back on, bars back on. Carbs back together, with 175F/178R jets,.05 shimmed rear,.035 shimmed front, 45 pilot,2.75 turns and 1 less hole in front slider.Pulled rear wheel polished aluminum outer and treated with Sharkhide protectant. Done for the day!
Old Mar 31, 2012 | 05:08 PM
  #149
RobtheDrummer's Avatar
RobtheDrummer is on a distinguished road
Nath and I took my carbs off, messed with the TPS, put in the thingamadoos to sync the carbs, and got it back together. Runs great.
Old Apr 1, 2012 | 11:48 AM
  #150
fasturd's Avatar
fasturd is on a distinguished road
Turn signals.
Finished a turn signal update and buttoned everything back up.
Re-tightened my billit sprocket cover too.
