Weight of the Superhawk
Old May 26, 2013 | 10:43 AM
I needed to weigh my bike to get accurate numbers with my Veypor gauge install. I was pleasently suprised to see that my bike was a little under the wet curb weight of 474 lbs. It was weighed with a bathroom scale which was spot on with an expensive scale at the doctors office.
My '98 Superhawk
The rear was 232 lbs.
The front was 231 lbs.
For a total of 463 lbs.
Note: besides being completely stock, my bike had a full tank of fuel, was de-PAIR'd, had the COP mod done, and a full baflectomy. It's also not a California bike
With my 6' 3" 225 lbs. along with the bike, I now know why the suspension feels so...shitty. The front even bottomed out a couple 'a times just pulling slowly into a driveway. Poor bike.
I was curious if anybody else has weighed thier bikes and what modifications were done, if any?
Old May 26, 2013 | 04:07 PM
nope here
Old May 26, 2013 | 04:34 PM
zanoj883's Avatar
zanoj883 is on a distinguished road
Originally Posted by CruxGNZ
Note: my bike was de-PAIR'd, had the COP mod done
What's the COP mod?
NM i found it
Old May 26, 2013 | 04:39 PM
Caffeine's Avatar
Caffeine is on a distinguished road
When you measured front and back did you prop the back wheel up so it was the same height? = bike level. it made a big difference on my SV.. I was trying to measure weight blance.. rider on bike % type thing.. found it was no where near 50/50.. more like 36/64, front to back.. but those numbers really changed when I ran the back tire up on a 2X6's to match the height of the scale. I wish I had a good old analog scale.. the digital would try to finish weighing when I was still trying to balance.. hard to get an accurate measurment
Old May 26, 2013 | 05:41 PM
JamieDaugherty's Avatar
I've measured mine at 445lb with a half tank of fuel. I've not done anything to save significant weight, except maybe the Jardine slip-ons.
Old May 26, 2013 | 07:00 PM
Yes, the bike was level.
I should have mentioned that I topped off the gas tank before taking the measurements. My bike also has full plastic fairings and stock wheels.
Jamie, what year is your bike? What wheels?
Old May 26, 2013 | 07:42 PM
Caffeine's Avatar
Wow that's a lot lighter then I would have thought. Know I want to weight it,! Need some analog scales.
Old May 27, 2013 | 04:54 AM
98
Stock wheels.
As mentioned, besides the pipes I've done nothing to reduce weight. Claimed dry weight is something like 423lb so I think mine is spot on where it should be.
Old May 27, 2013 | 06:44 AM
HRCA#1's Avatar
474 seemed a little porky, 450 sounds about right but I've never weighed mine so I frankly don't know..would like to though!
Old May 27, 2013 | 11:04 AM
Acording to the service manual, Dry Weight: 425 lbs. and Curb Weight 474 lbs.
This is for the non-California model.
If you have a bathroom scale, it's super easy. I just tip the entire weight of the bike onto the kickstand and then pickup either the front or rear tire. It's not as precarious as it sounds. It's extremely easy to balance.
Old May 27, 2013 | 11:28 AM
HRCA#1's Avatar
No argument here, just seems 49lbs for fluids and fuel seems high to me but again I have no empirical evidence, just my perception. Looks like it's time for me to buy 2 cheap analog scales!
Old May 27, 2013 | 12:12 PM
You figure the fuel alone for a full tank weighs ~25 lbs. (don't get me into the weight of todays fuel lol)
Old May 27, 2013 | 07:14 PM
Caffeine's Avatar
I had to see for my self! yep!
Full tank of gas, brimmed! Two brother pipes.. Michelin Power 3's (new)
226 Front
239 Rear
465!!
See for you self!
Front
Rear
Old May 27, 2013 | 07:27 PM
VtrInMtl's Avatar
VtrInMtl is on a distinguished road
Is that a Corbin seat, mine weighs 3 times as much as my stock one....
Old May 27, 2013 | 08:09 PM
Caffeine's Avatar
It's a Sargent. Didn't get the original seat so not sure if t weights more or less. Comfy though.
Old May 27, 2013 | 09:40 PM
Throw in a couple Gals of water and a battery and it adds up quick
Old May 27, 2013 | 09:45 PM
Yeah, why you guys weighing it full of gas? Dont you want to know the bikes weight not the fluids? So what, 465-25=440 right?
I was shocked to see that the new honda f6b wieghs 852. Makes the hawk look tiny.
Old May 27, 2013 | 11:05 PM
HRCA#1's Avatar
Cool
Not to be argumentative but I think the battery weight is already accounted for and the coolant is barely one gallon. So we're still a little light of 25#.
Old May 28, 2013 | 05:20 AM
Me personaly, I really just wanted to find out how much the bike actually weighed while riding it. I topped off the fuel tank to see what the maximum weight of the bike would be.
Old May 28, 2013 | 05:52 AM
I have to get off my duff and get mine on a scale. Based on the curb weights listed by the mags (477-480 lbs), along with the weights of the replaced components (I try to weigh the OEM and new parts to compile the difference), I expect it to be at 400lbs wet , or lower.....
Old May 28, 2013 | 07:46 AM
Damn!
Besides your battery, how did you loose so much weight? I know you got a crap load of cool bits on your bike, but which ones had the biggest weight loss?
Old May 28, 2013 | 08:11 AM
HRCA#1's Avatar
I can't speak for Mikstr but my Marchesini wheels cut 14 lbs, the battery is probably another 4-5 lbs, that might get me near 400 lbs dry. I'll be interested in what he's done to get where he is.
Old May 28, 2013 | 08:29 AM
I'm right at 401.5 with a full tank, ready to ride... I have had it lower, but my OCMD bit me in the ***, adding more fun parts...
On my bike, I have an alu subframe and fairing horn, as well as a lightweight battery, lighter flyweheel, you name it... And while the front end and swingarm upgrades are substantially beefier, they are also substantially less weight than stock parts... Along with lighter wheels, that's the main weight savings there, but all the little bits help...
A semi updated list of mods are found in my gallery, click the image below... It was too long to list in my sigline, even when using shortened words...
Old May 28, 2013 | 12:05 PM
Would love to have your aluminum stay and subframe Markus. I have a Graves aluminum front stay that I will eventually get around to fitting (needs some cutting and welding as it`s designed for a race upper fairing with no headlight). The real place to lose, however, would definitely be with the subframe (not only for the nominal weight, but perhpas more importanly for the location high up and back)....
I have an itemized list of the weight losses and will post at some point, once I get the final weight results....
Old May 28, 2013 | 12:21 PM
Well... If it wasn't completely cost prohibitive, I'd gladly make you one and send it over...
When I made mine, I basically replicated the stock one, but added a few cross spars and plates to strengthen it...
Old May 28, 2013 | 01:35 PM
I bought an alum,. sub from a 900RR and was looking at adapting it. However, without a welder and right tools, it becomes quite difficult. Paying someone else to do it quickly get ridiculously expensive....... we`ll see.......
tremaineiz
Apr 29, 2007 10:15 AM
captainchaos
Jan 23, 2007 03:51 AM
Radiaoktiv
Oct 24, 2006 08:11 PM
Scooberhawk
Aug 1, 2006 02:36 PM
ta2av
Jan 30, 2006 02:03 PM
