Wheel weight
Old Jan 21, 2007 | 05:43 AM
Wheel weight
Been lots of talk of rim swapping and wheel weight and hoping some of you all can "weigh in" on this. Just weighed the 900RR rear wheel on a new digital scale and it came in at 15.2 lbs. While I'm powdercoating and swapping tires I'll also weigh the 6 spoke RC51 front and stock superhawk rear and post them up as well. Sold the stock superhawk front wheel awhile ago so I didn't get to weigh that. Anyone else out there have a wheel sitting around and a decent scale? Curious to compare the weight of some different wheels we can use. A very quick search did net me this link some may find interesting. http://www.rc51.org/wheel.htm
Old Jan 21, 2007 | 09:52 PM
KC-10ENG's Avatar
Nice stuff! Thanks for the info
Old Jan 21, 2007 | 10:02 PM
EngineNoO9's Avatar
did I miss something... is the 900rr rear wheel compatible with ours?
Old Jan 21, 2007 | 10:06 PM
Yes, I have one Captain, but it's still got the guts in it and a tire on it. I have to get it ready to go to the powder coaters so I will weigh it before I take it over. BTW are you weighing the wheels with the bearing packages, cush drives mounted on the rear - how about rotors and sprockets. I think the wheel has to be totally stripped to go the the painters so I may have the option of doing it either way depending on what convention you are using.
Old Jan 22, 2007 | 03:50 AM
Good question...sorry. Yeah I measured with the bearings in but w/o cush, sprocket, and rotor. 15 lbs...not too bad when an RC rear is 19 and the expensive aftermarket wheels I'm trying to copy weigh roughly the same. And I haven't mounted it yet but all the info I've heard and read on here has said this wheel bolts up...
Old Jan 22, 2007 | 05:08 AM
KC-10ENG's Avatar
So what about the 5 spoke RC51 ones wheels off of the SP2s?? You would think that they would be a little lighter than the 6 spoke wheels off of the sp1
THe only thing is that you might have a hard time finding a rear rim that has only five spokes
KC-10ENG
Old Jan 22, 2007 | 06:47 AM
superbling's Avatar
I guess you've never looked closely at my avatar? LOL. Yes, the 900rr wheel bolts right on, no mods. I weighed it and it was lighter than the CHROMED stock unit it replaced. Chroming wheels is just stupid.
The RC51 wheels are the larger 6 inch size and, IIRC, need modding.
Old Jan 22, 2007 | 07:02 AM
EngineNoO9's Avatar
so on a stock bike do the f3 and 900rr wheels have any weight savings? They're both 5 spoke I think too which will look good
Old Jan 22, 2007 | 08:48 AM
superbling's Avatar
F3 is a 5 inch rim so you don't really want that. You can mount 180's on some 5 inch rims but it's not advised as it distorts the contact patch and slows down the handling. The 929/954 rears are 6 inch like the RC51 and probably need at least spacer mods. Chain clearance/alignment would also need to be addressed since that width is really for a 190.
From a mathematical standpoint, the 3 spoke design should be the minimum number of spokes while still providing strength. But from a weight standpoint, it's all in the details and materials. Some of the lightest wheels in the world are multi-spoke.
I got to lift an Aprilia marchesini forged mag rear wheel this weekend. It had a brand new 180 corsa, brake disc, bearings, cush drive and sprocket. IOW, ready to be installed on the bike. Even with all that, it weighed less than a bare stock honda rim (I changed my own tires so I'm pretty familiar with the bare rim weight). Incredible.
Old Jan 22, 2007 | 09:30 AM
EngineNoO9's Avatar
I meant f3 front wheel 900rr rear
Old Jan 22, 2007 | 12:16 PM
slo1's Avatar
slo1 is on a distinguished road
Just weighed a stock front, no rotors, bearings installed, and a crappy scale came out at 10.2 lbs.
6 spoke 5.5 rear (? no clue, came with a 929 front that I purchased), bearings, but no cush/sprocket cover or rotor, same crappy scale, 14.5.
dale
Old Jan 22, 2007 | 12:55 PM
superbling's Avatar
Yup, F3 front will fit. VFR (94-97 for sure) uses same rotors as 'hawk. The VFR's front wheels from 90-93 and 98-present will bolt on but the rotor mounts are different so you will need those too (same diameter just different bolt pattern).
Old Jan 22, 2007 | 01:08 PM
EngineNoO9's Avatar
f3 and vtr rotors are the same... I know that cause I'm using them on my vtr wheel
Old Jan 22, 2007 | 02:13 PM
shayne's Avatar
I am looking into lighter wheels too, and read some stuff written by a suspension about unsprung weight, which is bad on a bike.
They claim that every kilogram of unsprung weight that you can remove from the bike is equivalent to removing 8.5kg from the rest of the bike.
Pretty large variance I reckon, and well worth getting lighter wheels and rotors, and hubs and sprockets.
Not cheap though, ouch!!!!!!!
Old Jan 22, 2007 | 03:10 PM
Be cool if we could put a table together to make it easy for everyone once we figure out the different weights and what fits.
Old Jan 22, 2007 | 03:12 PM
RPV-Hawk's Avatar
RPV-Hawk is on a distinguished road
That makes it .3 lbs lighter than the RC51 front!:-D Assuming it's accurate.:-)
Old Jan 22, 2007 | 05:31 PM
superbling's Avatar
I stand corrected (de-confused really) and edited my post to reflect it. I was confusing interchangeablitity data with my 02 VFR.
Old Jan 22, 2007 | 07:33 PM
SNGPerformance's Avatar
SNGPerformance is an unknown quantity at this point
Yes Captain!! We need a sticky with Make, Model, Year, Weight, and what it takes to fit them up in the Knowledge Base.
Old Jan 23, 2007 | 12:17 AM
trinity012's Avatar
Wheel weight
Hi Capt. I just weight org SH wheels on baby digital scale today number came up w/9.2 front, 15.2 rear, 900rr rear (96) 15.9 (this rear wheel org white-privious owner paint black so the paint could go for a few more ounces), and 900rr w/rotor,cushdrive, hub weight 21 lbs. I dont know f3 front weight. Bcause I already put tire and rotors on it. According to SH project said VTR wheels weight lighter than pre honda CBR model, but I didn't seem like this info is true.
Old Jan 23, 2007 | 03:51 AM
Cool, thanks trinity. So basically the rear wheel sounds like a pretty even swap as far as the weight goes. Maybe if I drill a bunch of holes in it like my heelguards
cliby
Feb 4, 2010 09:25 PM
RCVTR
Jan 29, 2008 08:55 AM
tremaineiz
Apr 29, 2007 10:15 AM
Radiaoktiv
Oct 24, 2006 08:11 PM
Scooberhawk
Aug 1, 2006 02:36 PM
