rear spring removal to paint/powder coat
Old Apr 9, 2008 | 07:42 AM
andy9743's Avatar
i want to paint or powder coat my rear spring from yellow to red or black. my bike is on a stand with no weight on the rear, and the exhaust is off. is it as simple as just unbolting the shock bolts and pulling the assembley out?
thanks
andy
Old Apr 9, 2008 | 08:14 AM
superbling's Avatar
See if this answers all your questions:
https://www.superhawkforum.com/forum...nstall+removal
Old Apr 9, 2008 | 09:09 AM
andy9743's Avatar
sort of...seems like the shock should be easy with the exhaust off and the bike up in the air. the spring will not have tension on it and should come right off with the shock correct?
Old Apr 9, 2008 | 11:25 AM
superbling's Avatar
Nope. Spring isn't easily removable from the shock body (as in basic hand tools or it just slips off) like some other designs/aftermarket. At the very least, you'll need a spring compressor.
I recently posted this pic in another thread.
It shows an R1 shock I tried. The spring is from a Fox unit that I removed and painted to match. For those two shocks, I just had to run the pre-load the the absolute minimum which relieved enough tension on the spring that I could pry the bottom mount loose and slip the spring off. You can't do this with the stocker.
Old Apr 9, 2008 | 12:59 PM
andy9743's Avatar
so it's not feasible to remove and paint the spring? i have automotive spring compression tools i just don't want to get into more then i am bargaining for!
Old Apr 9, 2008 | 02:40 PM
hawxter996's Avatar
ole dirty bastard
Andy
once you get the shock off,use a compressor to remove the spring.
just be very careful lots of pressure.we dont want to read your obit.
Old Apr 9, 2008 | 08:49 PM
An automotive spring is longer and more easily compressed than a motorcycle shock spring. There's a special tool that compresses the spring by the bottom collar. Then there is another washer type doohicky with a slot in it that will slide out. The tool utilizes a 2 ton hydraulic jack to compress it. I would advise against trying to do it manually. You don't want to get hurt.
Old Apr 10, 2008 | 05:38 AM
andy9743's Avatar
where could i purchase one of these special spring compressor deals?
thanks again guys
Old Apr 10, 2008 | 06:12 AM
andy9743's Avatar
http://cgi.ebay.com/ebaymotors/MOTOR...spagenameZWDVW
somthing like this wouldn't work?
Old Apr 10, 2008 | 06:21 AM
superbling's Avatar
Sorry Andy but I'm no help as you're entering territory I've never pursued.
Old Apr 10, 2008 | 06:45 AM
cliby's Avatar
occasionally you can rent them. I want to empasize that done incorrectly and working over a very stiffly compressed spring you could lose a finger, an eye or even a head - not joking. Just walk the shock into your local shop and have them use their compressor to remove the spring for you and take it back to reinstall when painted. safe, easy and if they charge you to do it more than 5 dollars don't go back!
Old Apr 10, 2008 | 06:46 AM
I'm pretty sure that tool only works on a offroad bike as those springs are similar to a automotive... longer and lighter to compress... The spring on the VTR is quite a tough one...
Old Apr 10, 2008 | 03:42 PM
andy9743's Avatar
the more that i look at the dumber i feel...the shock and spring will come out as one unit correct? i was thinking that the shock would drop out the center and the spring would be left in the bike. it should come out all as one right? dumbass. sorry guys i making more of a job out of this then i need to i think!
Old Apr 10, 2008 | 03:44 PM
andy9743's Avatar
bling you have done more to answer my questions and inspire me to make this bike into what i'm working on then anyone...i'll let you off the hook this time, as long as you're not mad when you see my bike back together looking like your superbling but in red instead of orange!!
Old Apr 10, 2008 | 04:16 PM
Eh... not to be glib or anything... but "which" superbling???
I have so far seen... oh say three different shapes of it? perhaps more?!
Mr. bling likes to experiment me thinks... And there are a few more of that kind around here...
Old Apr 10, 2008 | 06:01 PM
Andy, that might work. Go slow and be careful. Compress each side evenly.
Old Apr 10, 2008 | 09:31 PM
happytrack44's Avatar
WERA #44
I have a purple Hyperpro spring on my stock shock. You can have the whole thing for 115 plus actual shipping to you, as I have purchased a Penske and it is now redundant.
Old Apr 10, 2008 | 09:34 PM
WERA #44
By the way, Changing the spring was done by a guy with a really nice wall mount Snap -on strut compressor and great care, as it isn't as easy as a car. Careful, It will have your fingers!
Old Apr 14, 2008 | 02:16 PM
trinc's Avatar
there is also that spring wrap ( split down the middle ). you can buy it in any color... and you don't have to remove the spring.
tim
Old Apr 15, 2008 | 05:27 AM
andy9743's Avatar
tim
this sounds interesting, i'll have to check into this. any links?
Old Apr 15, 2008 | 06:58 AM
andy9743's Avatar
hmm didn't find anything are you referring to split loom like for automotive applications? (wire hding and what not?)
7moore7
Mar 22, 2013 09:02 AM
budd
Mar 25, 2011 07:19 AM
j shizzy wizzy
Oct 27, 2010 06:29 AM
Cleveland
Mar 31, 2009 11:26 AM
redlinetech
Mar 23, 2007 06:19 AM
