new member
Old Jul 19, 2012 | 10:25 PM
Nigel King's Avatar
Nigel King is on a distinguished road
new member
hi all,i have a question regarding this rr from my 1987 cbr 600f ,well a few questions . 1 is this the right one for my bike .2 i see it has the sh prefix,shunt type is there a mosfet fh type from another make/model of bike that will work.this one has a power drain of 6 v with the bike off and has fried two cdi units and cooked 2 batterys.thanks for any help.more questions will i have any problems using the r1 rr as its from a 1000cc bike and i have a cbr 600f such as the amps needed,my bike has an 8 amp/hour battery. also i picked up a scorpion race can and was wanting to know if i can use it without changing jets or air filter . also anyone suggrst how i can remove the micron can as im unable to split the joint in pic . thanks again to saige and wolverine for the replys
Attached Thumbnails new member-374640_3035193363969_1386998147_33167840_1676408470_n.jpg   new member-600052_4283618133808_281679116_n.jpg   new member-578732_4283574172709_1590511890_n.jpg   new member-382521_4283587813050_295989397_n.jpg
Old Jul 20, 2012 | 06:37 AM
saige's Avatar
the boss
hi,welcome to the site,do not use those R/R's
use R1 rectifiers with the fh on it,that is your best option.
check ebay or your local craiglist for bike part outs.
Old Jul 20, 2012 | 12:13 PM
Welcome Nigel. You were in the right section to answer your own question (Knowledge Base).
mosfet-regulator-rectifiers
Old Jul 21, 2012 | 12:14 AM
Nigel King's Avatar
thanks saige and wolverine for the info i have a few questions regarding my bike jus not sure if this the right section
Old Jul 21, 2012 | 06:27 AM
saige's Avatar
the boss
the can should just come off the pipe,it may be stuck,but just maybe it was made as a one piece.
someone they may or had one of those may be to answer your question better.
you can put those pipes on without doing a complete rejet,but should/do need to mod the carbs a bit.some light work and patience will get you right.here is a link for the carb setup that should get you in the area you need to be in with these cans.
https://www.superhawkforum.com/forum...-set-up-24769/
here is a link to the pair removal,do this while you got the carbs off.
https://www.superhawkforum.com/forum...-removal-9875/
here is the link to do the tps mod,this is done while the carbs are off too.
https://www.superhawkforum.com/forum...n-sensor-9876/
here is the link to down load the service manual.
https://www.superhawkforum.com/forum...-manual-11365/
Old Jul 21, 2012 | 07:18 AM
Nigel King's Avatar
thanks saige do have a manual also the can is not a 1 piece just stuck fast an thanks for the carb setup info nice one
Old Jul 21, 2012 | 07:58 AM
If you have a CBR600f none of the links provudes will be of much help as they are VTR specific.
That is unless you have a VTR and I missed it in your first post.
Old Jul 21, 2012 | 08:03 AM
saige's Avatar
the boss
yea,he only has the cbr,i somehow missed that,i think my age is setting in lol
Old Jul 21, 2012 | 08:35 AM
Nigel King's Avatar
no jus a cbr at the mo thumbs up for superhawk forum had no help from cbr forum as yet thanks for all the help guys much appreiciated
Old Jul 21, 2012 | 10:54 AM
Nigel King's Avatar
pics for saige
pics for saige
pic 1 wires from the rr
pic 2 white rr plug 3 yellow wires
pic 3 red rr plug 2 wires with red/white stripe 3 green ones with earth ring
pic 4 harness plug ,2 red/white wires 2 green
pic 5 white stator plug ,3 yellow wires
Attached Thumbnails new member-549108_4322306100983_1608453507_n.jpg   new member-205237_4322328341539_878004779_n.jpg   new member-255338_4322330941604_485264890_n.jpg   new member-382414_4322291740624_415342283_n.jpg   new member-547751_4322270980105_1491731350_n.jpg
BigSquirmy
Sep 17, 2011 07:08 AM
BlackhawksFan
Apr 29, 2010 08:11 AM
benny6169
Mar 7, 2010 05:16 PM
synaptik
Apr 12, 2008 07:48 PM
GrayHawk
May 16, 2007 09:41 AM
