Factory Pro +4 ignition advance rotor for...?
Old May 30, 2015 | 08:26 AM
Because of my engine build, I can't use this Factory Pro +4 ignition advance rotor anymore. I wondered if anyone here with access to the right machines might want to take on making a couple dozen of these, or however many to make it profitable. Or heck, maybe scan it and make the data available.
Just thought I would throw it out there.
Old May 30, 2015 | 12:29 PM
NZSpokes's Avatar
Dibs!
If you put one on top of the other, do the inner teeth line up? I would doubt it but at a long shot could you not just file another flat?
Old May 30, 2015 | 01:02 PM
Originally Posted by NZSpokes
Dibs!
Here's a shot of the inner teeth lined up. You can see how the FP rotor is slightly different than stock.
I'm not sure what you mean by your comment of filing another flat.
I removed this FP rotor, because I'm installing Webcams (grind #189), JE 11.5:1 pistons and ported heads in my engine. With other engine builds like this, it was recommended that the FP rotor be removed, because of too much advance. So, I swapped back to a stock rotor.
No calling dibs yet. Not sure what I'm doing with it in the future
Old May 31, 2015 | 06:49 AM
Was it the second gen VTRs that did not benifit from the FP 4* advancer? Or some other mid year production change?
Old May 31, 2015 | 08:58 AM
There was a really informative discussion on this topic...here.
And to make things interesting, check out post #13...here. So, you might have purchased an ignition advance rotor, but your engine is not being advanced at all.
Old May 31, 2015 | 09:50 AM
ren's Avatar
ren
I am great with CAD design in Solidworks and could draw a model of it that can be used to make blueprints for a machine shop
Looks like it is stamped possibly, could be hard to replicate to be honest
Old Apr 24, 2016 | 11:08 PM
Braymond's Avatar
Braymond is on a distinguished road
Has anyone tried cutting out the center of a stock gear, spin it 4 degrees, and then welding it back together?
I just ordered 4 of the stock pieces from Partzilla. They're only about $7 each. I figure I can experiment a little.
Bill
Annapolis, MD
Old Apr 25, 2016 | 05:00 AM
I have several of the stockers laying around too. Never thought about cutting and welding the stock one. One thing to note, I am not sure you can just cut it and rotate it 4 degrees. But now you have me curious. I will look on the Factory Pro gear and see how far it is rotated compared to stock. It wouldn't be very hard to cut the center out with a hole saw and then tig weld it back together.
Old Apr 25, 2016 | 05:14 AM
Pidge's Avatar
Bill
Annapolis, MD
I count 25 splines so if shifted by 1 tooth timing would change by 360/5= 14.4 degrees.
Old Apr 25, 2016 | 05:16 AM
Crux,
Please explain what mysteries lurk in your new engine that facilitates removal of the ignition advancer!
Just curious of course.
Old Apr 25, 2016 | 06:40 AM
Originally Posted by kenmoore
Crux,
I haven't removed the ignition rotor. With my new engine build, I just replaced the Factory Pro part with the stock part. I read that it isn't a good idea to run these cams and high compression pistons with the ignition advanced.
Concerning cutting and welding the stock rotor, it's four degrees of crankshaft rotation.
Old Apr 25, 2016 | 11:35 AM
Hangfly's Avatar
Here is a photo of mine with part numbers.
The seller of my current VTR said "Oh yeah, I have this too.Never did install it."
I think I will hang on to it for now.
Old Apr 25, 2016 | 04:25 PM
Fastguy59's Avatar
I'm toying with the idea of contacting one of my pals who used to work for HRC and trying to obtain the mapping data for the ECU and using that to have mine flashed locally. The initial advance of 4 degrees works really well, but needs to be retarded back to stock or maybe even slightly below stock above say 4,500rpm. A fixed mechanical advancer can't do that...
Old Apr 25, 2016 | 05:16 PM
If that falls through, I have a HRC unit that you can copy the data from. Just as long as it doesn't get erased, I don't mind helping out.
*In fact, isn't there a company that does a custom tune to your ICU? I am pretty sure there is a thread on here about this.
*I appologize if any of the above information is incorrect. I just had two small surgeries and I'm tripping ***** on pain killers.
Old Apr 25, 2016 | 10:53 PM
Braymond's Avatar
If there's a thread here on ICU/ECU tuning/re-flashing I can't find it.
Bill
Annapolis, MD
Old Apr 26, 2016 | 12:47 AM
Stephan's Avatar
Bill
Annapolis, MD
something is written here, starting on page 4 in the middle by MK_WF.
www.vtr1000.org ? View topic - Red storm dyno - hp on engine
In short, you can just buy Ignitech unit with stock map for VTR1000F, and do whatever map you want. FP 4 deg advancer is a bit outdated technology ... :-)
Old Apr 26, 2016 | 06:31 AM
Stephan
which Ignitech did you buy and use?
Do you have a part number for the specific one that was plug and play?
programmable ignition units
SPARKER TCIP4 (standard) $141
SPARKER TCIP4 (full version) $149
SPARKER HONDA TCI $145
SPARKER RACING 3 $217
SPARKER DC-CDI-P $154
SPARKER DC-CDI-P1 race $162
SPARKER DC-CDI-P2 $162
PARKER DC-CDI-P2 RACE $192
Prices for any of them are reasonable, so Im only concerned with getting the right box.
Thanks
Old Apr 26, 2016 | 06:44 AM
Stephan's Avatar
Erik: I bought TCIP4 (standard) specified for Honda VTR1000F. There was preload stock map, and the same connector as on original CDI. Just plug and play. Then you need USB to serial adapter that is working (with FTDI chip) and connect it with computer. Nothing really difficult.
Old Apr 26, 2016 | 06:57 AM
Outstanding, thank you.
Seeing as this is a better option then the unavailable advancer at only slightly more $$..what the heck
Email sent to order, now I wait for a reply
Old May 4, 2016 | 08:54 PM
Crux, I PM'd you.
Call me tomorrow...
Old May 5, 2016 | 12:02 AM
Crux, I PM'd you.
Call me tomorrow...
Oops. I replied to your PM before I saw this.
Old Jun 1, 2016 | 06:47 AM
Did you get a response to your inquiry? If so will you provide me with the email that you used. I am not able to find more than the description page for the TCIP4. Thanks in advance.
Old Jun 6, 2016 | 06:00 AM
Hello,
Has original unit 16 or 22 pin connector ?
We can offer programmable unit TCIP4 standard with connector adapter.
unit TCIP4 standard 141 USD
connector adapter 21 USD
Freightage DHL 52 USD
Useful accessories is USB/COM cable for connection to PC 15 USD
Payment method is card payment or PayPal.
Should we send invoice to you ?
We will also need to know your phone number for forwarder.
Regards.
Jiri Krejzl
IGNITECH
Old Jun 6, 2016 | 08:59 AM
Hello,
Regards.
Jiri Krejzl
IGNITECH
Thanks,
I turned my brain on and easily found the full web site.
Old Jun 12, 2016 | 03:36 PM
Fastguy59's Avatar
Programmable ECU
Thanks,
So has anyone actually bought and programmed one of these ECU's. If so did you do the programming while on a dyno to measure the results of changing the ignition advance/return curve?
Old Aug 10, 2023 | 03:06 AM
Mallebollia's Avatar
Mallebollia is on a distinguished road
Have you been sucessfully with obtaining the Data?
Anyone got their fingers on the original Honda mappnig?
CaryDG
Aug 9, 2023 05:16 AM
Letsrideinsc
Sep 6, 2016 09:05 AM
Matty
May 15, 2009 12:26 AM
VFR79
Mar 26, 2009 09:32 PM
