Buying a used engine...
Old Jul 28, 2009 | 11:38 AM
Chester3000's Avatar
Chester3000 is on a distinguished road
Hey.
I'm about to go look at a used engine in the next few days.
What should I look for on these engines?
The guy says it has only 3000mi, and it was a strong motor before he crashed it.
I don't think the engine can be started, so I have to take his word for it.
I have tools and can do various tests, ie: compression, or valves, etc...
So what should be looked at on these bikes?
I know next to nothing about hawks Other bikes yes but these guys, no.
Thanks for any help.
Old Jul 28, 2009 | 12:06 PM
FL02SupaHawk996's Avatar
Fastest Color
Originally Posted by Chester3000
Hey.
Chester, unless you can pull the heads off and look down the holes there's not much you can do other than take the plugs out and turn the engine over by hand to make sure it's not seized...
Depending on the miles you may want to bore and rebuild it anyway using oversized pistons...
Old Oct 13, 2009 | 08:34 PM
Bridge_Boy's Avatar
Bridge_Boy is on a distinguished road
I have a 2002 Hawk will a complete 1998 motor swap into it without a great deal of work? My CCT failed and bent my front two valves. So if the swap is difficult rebuilding the head is my better option. A knowledgeable opinion would be greatly appreciated
Old Oct 14, 2009 | 08:54 AM
The basic motor never changed over the life of the bike. The only thing you'd have to swap off your old bike (to my knowledge) is the small thermosensor. (used by your digital dash) However reinstalling the engine into the frame requires tools only available from Honda. If your piston is not damaged from the valves hitting it, you could swap just the head.
Old Oct 14, 2009 | 09:41 AM
Those tools can be made using a socket of the right size (can't remember if it was 17 or 19 mm) using a file and hacksaw...
Old May 25, 2012 | 10:21 PM
Actually, you dont need to change the thermosensor cuz it stays with the fram and liquid cooling system. I thought the same thing before my motor swap a few months ago. How much is the motor?
Old May 25, 2012 | 10:26 PM
Well as it was almost 3 years ago.....
Looking for a used engine?
Old May 25, 2012 | 10:29 PM
OK it is officially past when I should've gone to sleep......
faz
Aug 31, 2014 03:28 AM
memmakersorg
Apr 26, 2013 04:04 PM
Damm1t
Mar 29, 2012 07:48 PM
pwshadow
Mar 7, 2011 03:37 PM
popcornchicken
Forum Feedback
May 21, 2009 05:31 PM
