backfiring issues on the hawk after pair system disabled...
I posted about this awhile ago and never got an exact answer.... Here's the deal. Disabled the pair system by flipping the reads and putting them back on... Afterwards while maintaining 3k rpm I'd get backfires and the bike kinda shakes a little... Now my question is would this be caused from air leaking in still or a bad tune maybe? I'm gonna go ahead and get block off plates and completely remove it all. hopefully that fixes it but if it doesn't then what?? Reason I'm confused is cause it only does it at 3k rpm. When rolling through that band it's fine. But cruising at like 25 mph down main street which unfortunately puts me at about 3k rpm the superhawk is not happy....
Re: backfiring issues on the hawk after pair system disabled
never did this before but it was never too happy with cruising 3k or below before i did the pair system disable. it'd sputter a little
I have found the PAIR system to become noticeable when you roll off the throttle, and not as much at constant RPM. My suggestion would be to install the block off plates, and then, if the problem persists, we can help figure it out here in the forums.
Sounds like the classic 3k lean stumble. Generally caued by the needle position in the carbs. Do you have a jet kit installed? The needles probably need to be raised. Try 1 notch (dropping the snap ring raises the needle) if you have a jet kit. A small washer installed under the "hat" on the stock needles apparently also helps. Others here who have shimmed the stock needles can help more with that.
what exactly is the PAIR system...and where is it located? i think mine is removed but i dont know for sure because it still pops when i roll off the throttle. i have aftermarket pipes and a DYNO jet kit...
sweethawk996
Feb 18, 2010 01:22 PM
EngineNoO9
Dec 22, 2005 01:06 PM
