wont start
Old 02-23-2011, 02:45 PM
megahawk04's Avatar
megahawk04 is on a distinguished road
wont start
i have a 1998 superhawk that was sitting for about 2 yrs i have recently tried to commission it, i drained the tank put new gas in it changed the fluids all around, i have new plugs for it, but can not seem to get the wires off the old ones,(is there a trick to this?) when i turned the bike over it cranks, but wont start i know i getting fuel cause i sprayed the carb with starting fluid (the vehicle kind!) and no go, so any easy ways to check spark? also if i have spark where should i check next? any help is appreciated!
megahawk04 is offline
Old 02-23-2011, 03:10 PM
Wicky's Avatar
Did you drain the carbs of gas before storing her up - if not try a search here for "cleaning carbs" 'starting problems' for solutions.
Of late there are a few coming out of hibernation and suffering the same problem.
Wicky is offline
Old 02-23-2011, 05:12 PM
Try twisting the plug boots a bit first and then try to pull them off.
As for what to check, you need fuel,spark & compression for the engine to run. So if you have spark, make sure you really do have fuel, then do a compression check.
But if you drained the tank and didn't pull the carbs and clean them very well, that is the place to start.
8541Hawk is offline
Mr.Lojo
02-07-2015 02:48 PM
USAFrider
07-24-2007 05:02 AM
ali_squidz
04-07-2007 05:57 PM
Tonyzz
03-29-2006 01:20 PM
Shmittay
11-03-2004 04:11 AM
Quick Reply: wont start
