Well i messed something up....
I did the fork seals yesterday. Had to take off the tank to suspend the bike. I'm fairly certain I put everything back the way it came off. I turned the little petcock on the bottom of the tank off when I removed the tank and turned it all the way on when I put it back on. It's acting like its having fuel delivery problems. Sometimes I can get it to rev above idle but when it does its very uneven and choppy like a jet is clogged or something. Here's a video of it running. It usually idles around 1100 rpm.
https://youtu.be/TMZqdj0jfug
No idea where to start. I checked the vacuum line to the petcock for leaks but I found nothing. Probably should put it out by the curb with a free sign on it.
Cheesedrug
Jun 8, 2006 02:51 PM
