Well i messed something up....
I did the fork seals yesterday. Had to take off the tank to suspend the bike. I'm fairly certain I put everything back the way it came off. I turned the little petcock on the bottom of the tank off when I removed the tank and turned it all the way on when I put it back on. It's acting like its having fuel delivery problems. Sometimes I can get it to rev above idle but when it does its very uneven and choppy like a jet is clogged or something. Here's a video of it running. It usually idles around 1100 rpm.
https://youtu.be/TMZqdj0jfug No idea where to start. I checked the vacuum line to the petcock for leaks but I found nothing. Probably should put it out by the curb with a free sign on it. :cool: |
PVLIR - Petcock Vacuum Line Inadvertent Relocation ...
Well i sure did didn't I. What's the other one for?
Originally Posted by Shaken
(Post 389056)
