Water pump turbine question
Old Jan 1, 2019 | 04:12 AM
melouse's Avatar
melouse is on a distinguished road
Hi !
happy New year everybody !
while repairing my clutch cover (it was drilled after i fell down), i noticed that the water pump sprocket doesn't spin freely when i make it turn with two fingers.
is it normal ?
Is it because of the seal that "rubs" ?
Old Jan 1, 2019 | 06:56 AM
Originally Posted by melouse
Hi !
is it normal ?
There is some resistance due to the oil and mechanical seal, The impeller should not "spin" like a top.... but it should not be hard to turn either,...
Really hard to confirm or deny yours is as it should be over the Internet.
Only three reasons I can think of that would be at issue.
  • Damaged bearing
  • Impeller seated to far into cover and rubbing the side case cover
  • Impeller not seated far enough and impeller rubbing the pump cover
The impeller seated depth tolerance range is very small, only 0.27mm. If its off more then that it rubs. The impeller can be driven in 1/2 mm easily with a case cover and exposed impeller being roughly handled.
Its easy to spot though, look for a "ring" of wear in the side case cover behind the impeller and in the water pump cover.
Or better measure the installed depth of the impeller using a depth mic, or good caliper
Old Jan 1, 2019 | 08:02 AM
melouse's Avatar
I don't think the bearing is damaged, because there is no hard point when you hand-turn the sprocket.
for the impeller, i'm going to measure it.
In fact, i know it's not supposed to be fully free, but i found it really harder than others water pumps i use to handle.
it must eat a lot of horsepower.....
Old Jan 1, 2019 | 08:03 AM
melouse's Avatar
Thanks for Your answer !
Old Jun 19, 2021 | 03:51 PM
2wheellife's Avatar
2wheellife is on a distinguished road
Water pump turbine doesn’t move at all
Hey there, I got an 04 and she started overheating, took the case off water pump turbine housing and tried to spin it by hand, doesn’t move at all, is this normal or does it need voltage to move?
thanks in advance for any feedback
Old Jun 19, 2021 | 07:11 PM
Water pump is mechanically driven, not electric. No voltage needed. Crank the engine, viola. Not advising you try it with the cover off.
Old Jun 19, 2021 | 07:49 PM
2wheellife's Avatar
Troubleshooting
Was trying to see if there was any rough spots on the bearing that it should have, trying to narrow down as to why it’s overheating. Oil level is good, thermostat is swapped out, cooling fan functions, no air pockets in the cooling system, checking the water pump turbine was the last thing I wanted to check.
I have checked to see if there was anyone on here that has swapped it out before as a DIY
thanks for the feedback.
Bald Eagle
Apr 29, 2018 05:36 PM
Rebirth98
Apr 9, 2015 04:15 AM
shwinny
May 26, 2011 06:30 PM
ff
Dec 25, 2008 08:33 AM
inderocker
Feb 12, 2006 05:12 PM
