Water pump turbine question
Hi !
happy New year everybody ! while repairing my clutch cover (it was drilled after i fell down), i noticed that the water pump sprocket doesn't spin freely when i make it turn with two fingers. is it normal ? Is it because of the seal that "rubs" ? |
Originally Posted by melouse
(Post 408705)
Hi !
happy New year everybody ! while repairing my clutch cover (it was drilled after i fell down), i noticed that the water pump sprocket doesn't spin freely when i make it turn with two fingers. is it normal ? Is it because of the seal that "rubs" ? Really hard to confirm or deny yours is as it should be over the Internet. Only three reasons I can think of that would be at issue.
Its easy to spot though, look for a "ring" of wear in the side case cover behind the impeller and in the water pump cover. Or better measure the installed depth of the impeller using a depth mic, or good caliper https://cimg8.ibsrv.net/gimg/www.sup...54aab5e025.jpg |
I don't think the bearing is damaged, because there is no hard point when you hand-turn the sprocket.
for the impeller, i'm going to measure it. In fact, i know it's not supposed to be fully free, but i found it really harder than others water pumps i use to handle. it must eat a lot of horsepower..... |
Thanks for Your answer !
Water pump turbine doesn’t move at all
1 Attachment(s)
Hey there, I got an 04 and she started overheating, took the case off water pump turbine housing and tried to spin it by hand, doesn’t move at all, is this normal or does it need voltage to move?
thanks in advance for any feedback |
Originally Posted by 2wheellife
(Post 413858)
Troubleshooting
Was trying to see if there was any rough spots on the bearing that it should have, trying to narrow down as to why it’s overheating. Oil level is good, thermostat is swapped out, cooling fan functions, no air pockets in the cooling system, checking the water pump turbine was the last thing I wanted to check.
I have checked to see if there was anyone on here that has swapped it out before as a DIY thanks for the feedback. |
