VTR knocking noise
Old Mar 24, 2015 | 11:57 AM
Maico88's Avatar
Maico88 is on a distinguished road
VTR knocking noise
First, Thanks Big Jim, your thread has been very useful. I have been chasing a noise in my newly purchased VTR. Removing the rod caps and using plastigauge has indicated that both are within limits. The book calls for 15 ft lbs +120 degrees. This did not seem very tight? So, maybe I have been being nervous about my new Shawk. I recently sold a Ducati (1990 750 Sport) and remember it being pretty noisy, but I expected a watercooled vtwin to be quieter. I will put up a video when it is running and see what you think.
I thought that this pic might be of use.
Old Mar 25, 2015 | 08:26 PM
Big_Jim59's Avatar
If you had the rod caps off you need to install new bolts. Honda stresses this and it is best practice. They are not expensive.
What did the oil pan look like? You will have more indication of bearing failure if you see gold flakes in the pan.
You can give a listen to mine. To me it sounds like it has a loose valve but what do i know.
https://www.youtube.com/watch?v=T5whAvMAAFw
Old Mar 26, 2015 | 05:16 AM
SPRHK's Avatar
my e-penis is huge!!
SPRHK is an unknown quantity at this point
Maico88, The Superhawks are known for crappy cam chain tensioners. This very well could be your source of knocks.
Old Mar 26, 2015 | 06:50 AM
Maico88's Avatar
I have ordered new rod cap bolts. Used the old ones to do the plastigauge. Oil pan was clean. No flakes of any kind. I modified the factory cct's so that they are now manual. After listening to your hawk in the vids, mine sounds a lot like it. Guess that I have just been being an old woman. I did learn that taking off the rod caps is a real pain. Thanks for the replies.
Old Mar 26, 2015 | 08:36 AM
thetophatflash's Avatar
You could have also sent out an oil sample for analysis for metals suspended in the oil.
Old Mar 26, 2015 | 09:30 AM
I agree. It is a lot cheaper than one might think. Really tells you a lot about what is happening inside your engine.
Old Mar 26, 2015 | 05:26 PM
Maico88's Avatar
Sounds like a good idea. Whee do I send for analysis?
Old Mar 26, 2015 | 07:54 PM
Check your local yellow pages.
Old Mar 26, 2015 | 08:04 PM
Amsoil
OAI
Blackstone Labs
I've personally only used Amsoil before.
Old Mar 27, 2015 | 05:30 AM
Maico88's Avatar
Originally Posted by CruxGNZ
Amsoil
OAI
Blackstone Labs
Thanks CruxGNZ. I followed the link to Amsoil. Am going to order a kit.
Old Mar 27, 2015 | 07:55 AM
Big_Jim59's Avatar
You and me both. I worry like an old woman about my bikes and any noise. Honda says that you can torque new bolts to 15 foot pounds to check with plasitgauge. I think it calls for 21 foot pounds at full torque and then the bolts have stretched.
And that is a big YES! It is a huge Pain in the butt to do the rod caps that way. It is actually good that you checked. I just got through with a rebuild and i have a ticking sound I can't locate. I am going to ride it and try to ignore it.
Old Mar 27, 2015 | 10:16 AM
waltr's Avatar
Not Realy A Squid
waltr is on a distinguished road
Blackstone has a very good reputation with the Cummins crowd. Some of the guys send routine samples to monitor engine condition and change intervals.
Walt
Old Apr 1, 2015 | 04:15 PM
Maico88's Avatar
New rod bolts came in today. The book calls for 15 ft lbs + 120 degrees. I do not have a special tool to indicate degrees so I have put paint marks on the bolts 120 degrees apart to aid in the torquing process. Any suggestions?
Old Apr 1, 2015 | 05:15 PM
It's kind of late but can I ask at what RPM did you have the knock and was it constant or did it come and go?
Old Apr 1, 2015 | 05:56 PM
Maico88's Avatar
[QUOTE=8541Hawk;384312]It's kind of late but can I ask at what RPM did you have the knock and was it constant or did it come and go?[/Q]
Steady noise at all engine speeds. Does not seem to get any louder under unloaded engine speed increase. Did not hear it when I road the bike home after purchase. Really did not think that it was typical rod noise, but wanted to be on the safe side.
Old Apr 1, 2015 | 08:51 PM
Big_Jim59's Avatar
Connecting rod bolt 29 N·m (3.0 kgf.m , 22 Ibf·ft) + 120
Connecting rod bolt (standard) 20 N·m (2.D kgf·m, 14Ibf·ft) + 120 (this is for checking the oil clearance)
Old Apr 2, 2015 | 03:16 AM
Maico88's Avatar
You are right. Apparently I need to read more carefully. THANKS
Old Apr 4, 2015 | 11:31 AM
Fire Storm's Avatar
Fire Storm is on a distinguished road
Maico,
Please check also the Primary Drive gear assembly. It contains three springs that are to apply pressure to the clutch outer. These springs can sometimes break and have been known to cause the sound you may have been hearing...like the sound of worn out con-rod bearings.
Old Apr 4, 2015 | 02:52 PM
What's your screen name? Fire Storm? On the unofficial SUPERHAWK Forum? What daring! What outrageousness! What insolence! What arrogance!... I salute you.
Old Apr 4, 2015 | 06:45 PM
Maico88's Avatar
Originally Posted by Fire Storm
Maico,
You are not the first to suggest the primary drive. A good friend of mine (he runs a motorcycle repair shop) suggested that I check the springs. Unfortunately, he made the suggestion after I had already checked the rod bearings. The primary drive is next on my list of things to check. Thanks for the suggestion.
Old Apr 8, 2015 | 09:23 AM
Maico88's Avatar
Well, the VTR is back on the road. Several minor problems were attended to while it was apart. All of the low rpm running problems have been cured. The low fuel light works, and the radiator fan cuts on and off like it should. Replaced the connection between the stator and the regulator. However, it still sounds a bit like a threshing machine to me. That said I love riding it. Am going to ride it for a while before i go back in to look at the primary drive. Will post a video soon.
Old Apr 8, 2015 | 02:06 PM
When you look at the anti rattle gear check the advancer.
When I fitted the 4 degree advancer the engine became louder as far as knocks go.
Been like it for years without any drama.
Old Apr 8, 2015 | 04:24 PM
Maico88's Avatar
Thanks for the input. I have had a NT650 Honda for a few years, and riding it made me want a Superhawk. I have not been disappointed, but the engine is new to me. Did you replace the pulse generator rotor with a 4 degree advance unit?
Old Apr 29, 2015 | 10:45 AM
Maico88's Avatar
I removed the clutch cover and inspected the anti-rattle gear. Coukd not see a problem, however I went ahead and removed the anti-rattle gear. I reassembled the bike. The noise has changed dramatically. It no longer sounds like a rod bearing going south. It does make some noise but no longer says SHUT ME OFF.
Old Apr 29, 2015 | 05:28 PM
I made a thread about removing the sub gear (anti-rattle gear) with pictures, click here. You removed the sub gear and the three springs, correct? Maybe a spring fell out before you opened it up? One would think that the engine would make more noise after removing the sub gear, not less. Very odd.
Old Apr 30, 2015 | 03:47 AM
Maico88's Avatar
Guess I was not clear. The noise has not gone away. It has changed. All three springs were in place. They did fall out when I removed the bolt. I put them all back and held them in place with white grease. Am not certain which way to pre-load the springs in the anti-rattle gear or if there needs to be pre-load. I originally reinstalled the anti-rattle gear and reassembled the bike. There was no change in the noise. Somewhat frustrated, I disassembled the clutch side and removed the anit-rattle gear. Am going to ride it and see what happens.
Old May 13, 2015 | 01:48 PM
Maico88's Avatar
Finally ran into another Superhawk. It was a later model (2002 I think) than mine. However, it sounded just like mine. I guess that all is well.
Old May 17, 2015 | 06:42 PM
Big_Jim59's Avatar
Maico: I finally Superhawk out yesterday and took a blast around the country side. It has been raining hard every day here and this is the first chance I had to really ride it. To be frank, the VTR is a rattley mess at idle. It sounds like a piston rattle but it only comes from the clutch side.
I removed the anti-rattle gear with no real change. I have a hard time listening to its noisy cadence and I have a harder time trusting the bike since it let me sit with a bent valve. But when I put my helmet on the noise went away and all I could hear was the sound of the those big mouthed Two Brothers exhaust cans.
Because of my brush with the law on my last outing I tried to take it very easy but it didn’t work. It just wants to run. I found myself motoring through a rather scenic hilly part of my neighborhood. I was loping along at 4 grand running around 75mph. It put me in mind of an old Moto Guzzi I used to own.
It is a hard bike to ride slow and a hard bike not to stuff into corners. It’s funny, but when I first got on board I got cramps in my legs, the pegs felt so high. The reach to the bars is not bad for me but the pegs caused my legs to lock up. But, after a little while in the saddle it started to feel really right. I got tucked in on that Superhawk and it just pulled like a tractor. It was fun, nothing but fun. I need to do one more carb sync and then i think it's done. I guess i have to stop worrying about the rattly engine sound.
jbrobinson08
Sep 3, 2022 07:35 AM
gti52
May 17, 2015 08:15 PM
996vtwin
Sep 13, 2011 01:31 PM
ericrosendall
Nov 25, 2009 07:30 AM
Reason
Jan 28, 2009 08:44 AM
