Valve Adjustment Tolerance - Consensus?
Old Dec 15, 2014 | 12:00 PM
thedeatons's Avatar
Specs are: .006 Intake - .012 Exhaust
2 of my Intakes are .005
1 of my Exhausts is .011
The rest are all perfect.
Would you take the time to get them perfect, or leave them?
The bike has like 34k miles on it
James
Old Dec 15, 2014 | 03:31 PM
thetophatflash's Avatar
I wouldn't. Been there, didn't.
Old Dec 15, 2014 | 04:43 PM
thedeatons's Avatar
Lol
Old Dec 16, 2014 | 06:56 AM
thedeatons's Avatar
Anyone else?
Any truth to someone quoting Hawk: set them all to the loose side of the tolerance to get more mid range torque?
James
Old Dec 16, 2014 | 10:16 AM
If your confident that the measurement that you have taken is accurate, as you know, are just at the spec limit. The clearance shrinks with wear. Are you thinking of opening the in spec valves?
I would, because of my ocd, make them all the same one direction or the other. What else have you got to do when it's too cold to ride?
Wouldn't a bigger gap retard the valve timing? and if so does .001mm really make any difference in torque curve?
Curious as well.
Old Dec 16, 2014 | 10:19 AM
thedeatons's Avatar
What else? I'm powdercoating, polishing, changing rear brake master cylinders, changing to stainless fasteners, removing thermostat housing, changing coolant tanks, removing carb heater lines.... I'm not really that busy....
LOL
I'd like to know more about putting them all to the loose end of the spec....
James
Old Dec 16, 2014 | 01:49 PM
rick's Avatar
rick is on a distinguished road
I'd leave it as is.
Old Dec 16, 2014 | 04:25 PM
LOL
James
A good resource to understand valve timing and changes in the power curve is A. Graham Bell's '4 Stroke Performance Tuning'.
Old Dec 25, 2014 | 03:46 PM
thunderbolt's Avatar
thunderbolt is on a distinguished road
Your intakes are too tight and will only get tighter with use. Change them both out for the next thinner shim than is in there now.
Old Dec 25, 2014 | 06:06 PM
thedeatons's Avatar
That's a bit vague, since i gave two different intake measurements. Which measurement are you saying is "too tight"?
Why did you only mention the intakes?
James
Old Dec 25, 2014 | 08:42 PM
I'd be more worried about tight exhaust valves.
Old Dec 26, 2014 | 02:29 AM
James
You said you had 2 x intakes at 0.005", that makes them the same not different.
The exhaust is 0.011".
Each of these measurements are 0.001" under what they are supposed to be which is 0.006". This does fit within the tolerance of + or - 0.001" just. But seeing as you are this far in I would change the shims.
The shims go up in sizes of 0.025mm which equates to 0.001" or 0.0009" to be precise. So you would have the option of going down by either one or two shim sizes. One size down would make the intakes 0.006" and the exhaust 0.012". Two sizes down would make for 0.007" for the intakes and 0.013" for the exhaust which would mean you would not then have to change the shims for a long time.
Old Dec 26, 2014 | 09:10 AM
thedeatons's Avatar
Oh i realize what happened, i said two intakes are .005, and the rest are perfect (meanijg .006, so in my mind i gave two different measurements.
Anyone know more info about hawk's theory of setting them all on the loose side of the spec to get more power in a certain rpm range?
Thanks for the comments so far!
James
Old Dec 26, 2014 | 01:22 PM
Technically less overlap on the valves will give more power in the midrange. How much and at what rpm is open to conjecture.
Old Jan 3, 2015 | 09:10 PM
superbeater's Avatar
I faced having one valve .001 too tight when I last did a check. I took the cam out and changed the shim to get the correct tolerance. If you are not going to do something about it, why bother to check? Just keep riding until something fails or you loose compression.
While you're at it, quit changing your oil. That's just preventative maintenance too.
All the other things your are doing require effort but they don't help the longevity of your bike. Get that cam out!
Old Jan 3, 2015 | 09:19 PM
OK, if you say that we have to, I guess that's the last word. I hope.
Old Jan 4, 2015 | 05:59 AM
thedeatons's Avatar
It was just a simple question...
James
barncat
Sep 15, 2013 09:21 PM
superman_006
Jul 24, 2010 10:17 PM
CentralCoaster
May 16, 2009 05:51 AM
dsevans
Jan 1, 2009 01:20 PM
AZZKIKER
Mar 21, 2006 09:43 PM
