Uh-ohh... coolant leaking out of mechanical seal inspection hole. What now?
Old 09-05-2007, 01:58 PM
vtrktm's Avatar
vtrktm is on a distinguished road
After riding a short distance today, noticed I had a wet right boot. Inspected the bike when I got home and noticed coolant leaking out of that tiny pin hole in the right crankcase cover the manual calls a mechanical seal inspection hole. Says if this is the case I need to replace the seal. Seems like there is quite a lot involved with bearing removers, mechanical seal driver tools, etc. required. Anyone done this seal replacement and can you do it in the garage without all this fancy stuff or am I best to take it to the shop?
vtrktm is offline
Old 09-05-2007, 04:27 PM
speedkelly@aol.com's Avatar
take a look
go to the knowledge base is this forum...click on service manual...and there you should be able to see if it is something you are capable of..good luck...basically gives you acess to the honda workshop service manual
speedkelly@aol.com is offline
Old 09-05-2007, 05:28 PM
vtrktm's Avatar
Tx man, I'll give it a try.
vtrktm is offline
Old 09-08-2007, 06:40 PM
vtrj's Avatar
vtrj is on a distinguished road
The jobs not all that difficult, i've done them in other bike's and i'm going to do the one's in my SH as soon as the parts come in. Just ordered them saterday, $125. for all the parts gaskets new oil, new coolant and such.
vtrj is offline
Old 09-08-2007, 07:06 PM
IIRC, this is a silver seal and you must be VERY careful pressing the new one in. I highly suggest you take this to the dealer to have it done. That way if it gets messed up they pay for their mistake, not you. Should only be $10-20 based on the fact that it really only takes about 15 minutes to do IF you have the right tools.
Hawkrider is offline
Old 09-21-2007, 03:00 PM
Not hard, but a press and the install tool is best. Plus you have to set the depth of the seal to a tight tolerance or the pump gear rubs the case. Pull the side case off, take to a shop as suggested. Pay the Min shop charge to have them install a new seal. Worth the $$ in headaches unless you have the right tools and knowledge
E.Marquez is offline
Old 09-21-2007, 04:02 PM
fundgh's Avatar
How much leak is too much leak? I have never had a wet foot, but I have noticed some fluid residue on the case below the hole. What is the risk in running it with a small leak?
fundgh is offline
Old 09-21-2007, 05:02 PM
were U bending over
and could it have also run down your leg onto your boot when you noticed coolant leaking out of mechanical seal inspection hole?
skokievtr is offline
Old 09-23-2007, 05:00 AM
vtrj's Avatar
I would'nt worry about seepage, you'll know if the seal is shot. The reason it comes out the hole is to prevent the two fluids from mixing inside the engine so it won't mess anything up unless it's really bad in witch case you'll get a wet leg.
vtrj is offline
Old 09-23-2007, 05:05 AM
vtrj's Avatar
The whole job only took about an hour. If you have a vise on your bench and a couple of sockets the right size you have a press.
vtrj is offline
Old 09-23-2007, 06:26 AM
gboezio's Avatar
That's what I do, I use a socket that fits the outer edges of a seal, a 12" 1/2 extension and a hammer, I gently tap the seal in place checking the clearance if required. The extension helps to hammer it straight, when you use a socket only it's impossible to hit the center and to get the seal straight. You need a steady hand, a bit off center you'll have the chance to try again... I do this for bearing races, seals, freeze plugs. Sure thing a press is a more steady force to apply when a back clearance is needed.
gboezio is offline
smokinjoe73
08-07-2012 08:16 AM
aamikah
01-16-2012 06:26 PM
maniac2313
06-28-2011 04:53 AM
cozart02
12-25-2006 09:23 AM
Quick Reply: Uh-ohh... coolant leaking out of mechanical seal inspection hole. What now?
