Mechanical Seal Break in?
Old Jan 8, 2012 | 10:23 AM
aamikah's Avatar
aamikah is on a distinguished road
Here is my question:
Does the mechanical seal need to swell before it seals?
Some background:
My mechanical seal started dripping coolant a while back so I decided to replace it. Ordered the parts and took the right side cover over to the dealer to do the install since I don't have a hydraulic press.
I reinstall the cover and start pouring coolant in the radiator when I notice a decent trickle of coolant pouring out of the weep spigot. I think there might have been a problem with the seal install so I take the cover back to the dealer and they tell me that it is normal, that the mechanical seal needs the engine to run a bit to "swell" the seal and then it will stop dripping.
Is this correct?
Thanks for any help. I took a quick look at mechanical seal posts on the forum here but didnt see anything about swell or break in.
Old Jan 8, 2012 | 11:12 AM
franz125's Avatar
franz125 is on a distinguished road
He did something wrong.Surfaces is ceramical no need any swelling.Check dimensions from manual.
Old Jan 8, 2012 | 11:16 AM
I just had a problem similar to this. Short answer: I don't think so.
What happened with mine; same story. Put coolant in and it poured out the weep hole. WTF? Ok, take the think apart and during the installation of the bearings, the mechanical seal had been broken. There are two notches in the mechanical seal that need to line up with the cover to orient it correctly (and I'm assuming keep it from spinning).
The top of the seal is some kind of plastic or ceramic or something, and if it's not lined up correctly when the bearings are put in, it physically breaks, creating a crack that the coolant runs through. I was fortunate enough to have a spare cover and replaced the seal being careful to line up the notches. Re-installed and the seal worked perfectly the first time I put coolant in it. So, there's a good chance it was damaged on install, and at least on mine it didn't break in (although it was a used piece, but I don't see that being an issue)
Old Jan 8, 2012 | 03:08 PM
matt365's Avatar
I don't know about this 7moore7. Manual doesn't state anything about lining up. You're saying the cover itself cracks, or the seal? -the seal on the water pump shaft, or the mechanical seal itself?
I just replaced mine, and it doesn't seem to be leaking at all?
A vice and a couple pieces of wood worked to press the water pump shaft in for me. Used a large socket and an extension to drive in the seals.
Old Jan 8, 2012 | 04:11 PM
Just the seal, hold on I'll take a pic of my broken one here in a bit. It's just two little notches in the seal- chances are that you lined it up correctly w/out thinking because that's the only way that it goes on (unless you break it by forcing it on like I did)
Old Jan 8, 2012 | 05:00 PM
Nm I threw it away...
Old Jan 8, 2012 | 09:38 PM
aamikah's Avatar
Ok, thanks everyone. I recently found out my cousin has access to a shop with a press and I may be able to use it. Bit of a drive but...
I'll take everything out and take a look. If I find anything broken, I wonder if the dealer will replace it, or assume I broke it?
Old Jan 8, 2012 | 10:17 PM
If you have a good assortment of large sockets and a 6" vise you can install it yourself. That's how I did mine. Mine wasn't leaking. It was replaced whilst replacing the engine cover.
Old Jan 9, 2012 | 10:12 AM
aamikah's Avatar
Ive got the sockets but not the vise. My cousin may have one in his garage though which would be less of a drive than the shop. I'll check this weekend. Thanks for the idea.
Old Jan 9, 2012 | 10:16 AM
I've used a large c-clamp and socket before too. These bearings aren't particularly loaded either...
Old Jan 16, 2012 | 06:26 PM
aamikah's Avatar
Ok, I followed your advice and found a way to press out the impeller with a clamp. Once out its obvious why the seal still leaked.
Here are some pics:
I used a 3in pvc pipe coupler to support the engine cover while pressing out the impeller:
I had to cut off about half an inch off the coupler to fit this in my 6" clamp. An 8" clamp would work better. I do not have clamp envy:
Here is the problem. The old impeller shaft is on the left and the one I just took out on the right. The dealer forgot to put in the ceramic ring into the new impeller! Also, the bearing is feeling a bit gritty and gets caught when I try to spin it. Not smooth.
Here is a look at the old vs new impeller. The old one has corroded a bit where the coolant leaked onto it.
smokinjoe73
Aug 7, 2012 08:16 AM
maniac2313
Jun 28, 2011 04:53 AM
HondaJim
Jul 26, 2008 09:19 AM
vtrktm
Sep 23, 2007 06:26 AM
gboezio
Mar 21, 2007 08:40 PM
