testing petcock
Old Jun 4, 2007 | 09:55 AM
gpzturbo's Avatar
gpzturbo is on a distinguished road
testing petcock
Is there any way to test to see if the petcock is alowing the proper amount of flow?
Old Jun 4, 2007 | 10:33 AM
There's really no specification on flow. It's either on or off. Hooking up a mighty vac to the line which goes to the nipple on the BACK of the petcock will give you on/off testing. Make sure the petcock is turned on. Use an 8mm wrench and I think fully CCW is on. If you pull the petcock off there is a strainer attached to it. That could be clogged.
Old Jun 7, 2007 | 08:49 AM
torquepeak's Avatar
torquepeak is on a distinguished road
I mixed up the attachment on the petcock when re-installing the tank.
After finding and fixing the problem, I tried pulling vacuum on the petcock to sync carbs and it will not hold vacuum. Is it vented or busted?
Old Jun 16, 2007 | 09:11 PM
Try a different hose and make sure connections are tight. If everything seems to be holding and you're still losing vacuum then the diaphragm is busted and you need a new petcock.
supermonie
Mar 5, 2009 04:31 AM
ericaa
Apr 24, 2008 04:06 PM
seaton001
Jul 17, 2007 02:21 PM
EngineNoO9
Sep 16, 2006 11:12 PM
Anonymous
SuperHawkForum Mailing List
Dec 30, 2004 11:09 PM
