Temperature gauge broken...
Old 04-26-2010, 08:59 AM
FinalBoss's Avatar
FinalBoss is on a distinguished road
I searched...
My temperature gauge doesn't seem to work (needle moves 1/8" when the key is turned and stays there) and neither does my fan.
Both those things point at something specific, anybody know what needs to be replaced?
FinalBoss is offline
Old 04-26-2010, 10:50 AM
The fan shouldn't come on until you go up in temps... So that's not really conclusive... The service manual has a test procedure to go through, download it and get to work... (link is in the knowledgebase)
Tweety is offline
Old 04-26-2010, 11:11 AM
PUSHrod's Avatar
The top of the thermostat housing has a Male connector, there should be a female lead attached to it. The sensor in the thermostat housing needs to send a signal to the cpu. No signal and the cpu thinks the motor is cold, low temp reading, no fan action.
Mine wasn't connected at the dealer when I bought the bike, I found the loose plug just poking around. Made the connection and function and reading came up.
If your's is connected, the sensor may be bad. If you have a vom and a pan of water on the stove, you can test it for function.
The only other thing that may cause that symptom is a large air pocket in the cooling system. Prevents coolant flow. Bleed, bleed, burp.
'Luck out there.
PUSHrod is offline
Tslapper
06-30-2011 10:07 AM
rray
10-26-2008 06:02 PM
Chitownson
01-14-2008 08:39 PM
Les
08-11-2007 05:57 AM
cliby
03-18-2007 11:50 AM
Quick Reply: Temperature gauge broken...
