Temperature gauge broken...
I searched...
My temperature gauge doesn't seem to work (needle moves 1/8" when the key is turned and stays there) and neither does my fan. Both those things point at something specific, anybody know what needs to be replaced? |
The fan shouldn't come on until you go up in temps... So that's not really conclusive... The service manual has a test procedure to go through, download it and get to work... (link is in the knowledgebase)
The top of the thermostat housing has a Male connector, there should be a female lead attached to it. The sensor in the thermostat housing needs to send a signal to the cpu. No signal and the cpu thinks the motor is cold, low temp reading, no fan action.
Mine wasn't connected at the dealer when I bought the bike, I found the loose plug just poking around. Made the connection and function and reading came up. If your's is connected, the sensor may be bad. If you have a vom and a pan of water on the stove, you can test it for function. The only other thing that may cause that symptom is a large air pocket in the cooling system. Prevents coolant flow. Bleed, bleed, burp. 'Luck out there. |
