strange noise..a have a few questions
Old Apr 3, 2009 | 11:51 PM
merlyn's Avatar
merlyn is on a distinguished road
hello ..I have a problem ...when I run my engine at neutral it makes a strange noise ...when I tight the clutch lever the noise dissapear...my vtr is a red one from 98 with 19k miles on the clock...sorry for my english I m from Romania
it is the CCT_?but the noise dissapear!
i use 10w 40 motul 7100 full syntetique double ester oil it is ok?... I change it every 3k miles
when I change the gear from 1 to 2 it makes a clunk noise ...like when I put in the first gear
I put a BMC race air filter on it ...it is ok?
thank you...with respect Andrew
Old Apr 4, 2009 | 12:07 AM
It's just the clutch, don't worry about it. The clunk from first to second is normal as well.
Old Apr 4, 2009 | 12:08 AM
merlyn's Avatar
thank you!
Old Apr 5, 2009 | 03:09 PM
oneup1982's Avatar
RubberRoaster
oneup1982 is on a distinguished road
A little tip for noises.... TURN UP YOUR IPOD~! They don't exist if you can't hear them.
Old Apr 6, 2009 | 12:59 AM
merlyn's Avatar
ha ha ha funy...the problem is I love to listen the engine sound
Old Apr 6, 2009 | 01:29 AM
RK1's Avatar
RK1
Not sure about the noise but it isn't the CCTs.
Shift from 1 to 2 makes more noise than other shifts. As long as you get positive engagement I wouldn't worry about it.
BMC race filter? I tried one on my VTR and no matter how I changed the jetting it ran poorly at low rpm. I went back to the Honda filter. If your bike runs OK with the BMC I wouldn't worry about it.
No need to apologize for your English. It's much better than our Romanian.
Old Apr 6, 2009 | 03:51 PM
merlyn's Avatar
Thank you RK1 ! In my opinion it is ok with the BMC air filter! The acceleration time response is much better in my case!When I changed the stock filter with BMC I went to the service and make a carb syncronisation!!>))
Old Apr 12, 2009 | 12:20 AM
Circuit_Burner's Avatar
guru of things sparky
Noise dissapearing when the clutch lever has pressure would indicate the pilot bearing is worn.
merlyn
Apr 7, 2010 02:53 PM
98greenchicken
Sep 18, 2007 05:33 PM
hazzy
Aug 26, 2007 07:50 PM
Otto Man
Jan 17, 2007 06:47 PM
F1 Fan in Nascar Land
Mar 24, 2006 08:15 PM
