strange noise..a have a few questions
hello ..I have a problem ...when I run my engine at neutral it makes a strange noise ...when I tight the clutch lever the noise dissapear...my vtr is a red one from 98 with 19k miles on the clock...sorry for my english I m from Romania
it is the CCT_?but the noise dissapear! i use 10w 40 motul 7100 full syntetique double ester oil it is ok?... I change it every 3k miles when I change the gear from 1 to 2 it makes a clunk noise ...like when I put in the first gear I put a BMC race air filter on it ...it is ok? thank you...with respect Andrew |
It's just the clutch, don't worry about it. The clunk from first to second is normal as well.
thank you!
A little tip for noises.... TURN UP YOUR IPOD~! They don't exist if you can't hear them.:p
ha ha ha funy...the problem is I love to listen the engine sound
Not sure about the noise but it isn't the CCTs.
Shift from 1 to 2 makes more noise than other shifts. As long as you get positive engagement I wouldn't worry about it. BMC race filter? I tried one on my VTR and no matter how I changed the jetting it ran poorly at low rpm. I went back to the Honda filter. If your bike runs OK with the BMC I wouldn't worry about it. No need to apologize for your English. It's much better than our Romanian. |
:evillaugh:Thank you RK1 ! In my opinion it is ok with the BMC air filter! The acceleration time response is much better in my case!When I changed the stock filter with BMC I went to the service and make a carb syncronisation!!>))
Noise dissapearing when the clutch lever has pressure would indicate the pilot bearing is worn.
