Starting Problems...CCTs?
Old Nov 14, 2006 | 07:44 PM
99Hawkboy's Avatar
99Hawkboy
After installing my APE manual cam chain tensioners I have noticed that the engine has been having some problems with starting. The starter will engage, stop for a quick second and then slowly turn the engine over. Never did this before... Could it be the starter or is the CCT turned to tight..?
Also my current setup for the CCTs is finger tight minus 1/2 turn..
thanks!
Old Nov 15, 2006 | 05:31 AM
zimm's Avatar
zimm is on a distinguished road
I had the same problem. CCT's are too tight. Loosen them up a bit.
Old Nov 15, 2006 | 07:59 AM
99Hawkboy's Avatar
99Hawkboy
Yeah thats what I kinda figure.. How do i know if I go too loose though?
Old Nov 15, 2006 | 08:16 AM
zimm's Avatar
I backed them off one at a time until they started making noise while running. Then slowly tighten until it quieted down, then I locked the adjustments in. No problems so far.
Old Nov 15, 2006 | 08:32 AM
SlowHAWK's Avatar
I agree to the too tight on the tensioners as well... I noticed my motor didn't turn over as fast as usual on the first restart, soon as I backed them off a 1/2 turn each, things worked just fine.
J.
Old Nov 15, 2006 | 03:22 PM
99Hawk's Avatar
99Hawk
Just back each off another 1/2 turn for a total of 1 full turn out.
I found that a full turn out (from finger tight) gave about the same plunger pressure as the stock CCT spring anyway.
Old Nov 15, 2006 | 04:33 PM
99Hawkboy's Avatar
99Hawkboy
Alrighty! Ill bring the bike back in tonight to adjust the front CCT.. The rear was easy but the font one is impossible to adjust w/out pulling the tank/air box off..
Old May 2, 2007 | 08:50 PM
Thumper's Avatar
So i am about to do the MCCT install. From what i have read most of you are running 1 turn out from finger tight setting.
Is this correct.
I have already pulled the vavle covers and checked valve clearances (15k so it was time) and all are with-in specs.
My plan is to do the rear first, put zip ties on the cam sprockets around the cam chain and sporcket to help keep the chain from jumping a tooth, make sure i am on RT timing mark and that the cam lobes are up and inward facing.
Other than that i assume its is a simple task to remove the Honda CCT, install the APE CCT and finger tighted - 1 turn out.
Of course i will need to verify this again after turning over several times and after starting.
Any other quick tips. I am more than comfortable with the process and have done stuff like this on in-line fours and my old CB750F has a Factory manual CCT and it works very similar.
I appreciate any updated comments, like how often you might have to re-check these from some of you that have had yours installed sometime.
Thanks agian for any comments you post
Old May 2, 2007 | 09:41 PM
I run lightly finger tight. Pretty much the same thing. Works well for me and the motor sounds like a....Honda. Imagine that! They should be adjusted with the engine at normal operating temperature.
Old May 5, 2007 | 08:39 PM
Thumper's Avatar
Well i successfully got them in and started the bike after the precautinary turn over by wrench and again with the starter with engine switch off.
She started right up and sound nice and quite. I went with finger tight ( as tight as my fingers could turn it) and backed it off 1/2 turn. I now need to ge the tank back on a nd take a test ride, warm up the engine, and the readjust as needed.
calitoz
Nov 6, 2025 10:45 AM
rc51utv
Dec 7, 2013 08:40 PM
bass4dude
Apr 7, 2011 07:08 PM
bass4dude
Feb 13, 2011 09:06 PM
Dave Wicks
Apr 11, 2007 06:13 AM
