question about fox shock
Been a while since I was in here looking around, good to see the long time hawkers still here!
I have a question about recharging a fox shock with nitrogen. The shock is a fox double clicker. The shock no longer is "clicking" when the blue damping adjuster ring is turned. The shock is not leaking oil so I assume it's because the nitrogen has leaked out from the reservoir over time. From some of my reading, I find that the nitrogen can leak out.
So...if the shock reservoir leaked the nitrogen charge can the reservoir be recharged or am I in for a rebuild to do it right?
When was the last time the shock was serviced? If it has been more than 3 yrs I would get it rebuilt.
Though I am a bit more **** about getting the rear shock serviced since snapping the shaft on an Ohlins shock due to putting of the recommended service interval.
Plus they work much better with fresh oil =)
foxy
that's the response I thought I'd get, and the riding season is hot just now. I got the forks re-valved and did some other work, that's when I discovered the clicker wasn't clicking on the shock. The reservoir is fine and the shock isn't leaking but setting the dampening on the shock is tricky without the "click". Maybe I buy one of Jamie's shocks and install it, get the fox shock rebuilt and sell it.
Before all that I would stop by Catalyst Reaction and see what they have to say about your shock.
https://www.crstuning.com/
Another FYI on your options.
If you want more info or another source for service is just go to Fox http://www.ridefox.com/service.php
I read a posting on another forum that mentioned that the shock needs recharged if the clicker stops. If it's mechanical there would not be any correlation between nitrogen charge and the click function. The shock seems to respond to adjustments made with the dampening ring on the shock but I'm making those changes by counting the number of turns out from all the way in.
I had my forks done by James at Super Plush in San Francisco, they may have information.
I guess my biggest concern is if the shock creates a safety issue.
Also, I just got the forks re-valved and re-sprung with linear springs and would like to get some riding in.
Like I said, the shock "looks" like it's in good shape; not leaking oil and no visible pitting on the shaft but I am concerned about failure during a ride.
I'd find a local shop that services motocross shocks - they will have the necessary equipment. Have them charge it to 190-200psi and you should be fine. This is something that needs to be done every other year or so anyway. It doesn't even need to be off the bike, I'd just ride in and have them do it.
Good luck!
Yes, low nitrogen pressure is definitely the reason for no clicks.
Good luck!
Good luck!
From (20-year old) memory, the adjustment wheel bears on a cross-shaft that engages the end of the needle that enters the shock shaft and adjusts the actual rebound bleed port size. Gas pressure pushes the needle out of the shock shaft so it sits in firm contact with the cross-shaft, and that pushes on the adjustment wheel. The adjustment wheel has detentes on the face that bears on the shaft. So no gas pressure = no detente action.
took the hawk in and got the reservoir charged to just under 200 psi. the detente is working again, yay! question is, why did the nitrogen leak out in the first place, is that normal? rebuild in order?
That's normal. The nitrogen in the reservoir should be recharged every 1-2 years as normal service. This goes for all shocks.
