Is it possible for CCT's to fail and lock a motor down with....
Old May 12, 2007 | 09:58 PM
BiggDaddyKool's Avatar
BiggDaddyKool is on a distinguished road
no other motor damage??? I am asking because I just had a lock down and want to know if I should just buy a new motor or try to look at my CCT's and see if I can replace the chain assy and be good to go. Any input would be appreciated.
Thanks ,
Chris.
Old May 12, 2007 | 10:17 PM
khanawalt's Avatar
khanawalt is on a distinguished road
From what I've read here, you may be able to salvage the engine, but you'll be replacing valves and possibly the piston, depending on the extent of damage. I think if it locked up, it's safe to say something's bent at least.
I have a set of APE manual tensioners that I have not installed yet, but your story is starting to make me nervous about running stock CCTs. How did yours sound before it failed? Some guys aren't that concerned because they believe it'll start making noise to warn them of impending trouble before it fails catasrophically.
Thanks ,
Chris.
Old May 12, 2007 | 10:30 PM
Mine ran flawlessly the night before it locked up while we were on a 5 1/2 hour ride. I started it the next day after checking the oil and let it warm up, as usual, almost to the first mark on the gauge. It sounded perfect. I put my helmet on and rode out my driveway and down the highway at apprx. 45 mph for about a 1/4 mile. All was fine until ALL OF A SUDDEN I hear what sounds like a rock rattling in the engine. I turn around, knowing this cant be a good sound and ride straight back to my garage door. I pulled up to the door to open it and the motor shut down. I pushed it inside and tried to restart it but it only clicked as if the battery was dead I pull the oil fill cap off so I could see if the engine was turning and put it in high gear then pulled in the clutch and pushed the bike and popped the clutch but the motor didnt turn. Locked up.
Long story short NO WARNING AT ALL. Also not 100% Sure its CCT's but I will be sure to let everyone here know as soon as I find out for sure.
Old May 13, 2007 | 07:55 AM
What year and how many miles...
Lets just say .. If you were to change a few words in the above post.. It would be the typical aftermath story of failed CCT's
Old May 13, 2007 | 07:59 AM
Oh, and to your question.. No, if the CT's failed in the way you describe.. At the very least you'll find bent valves.. If you lock out, that’s all you'll find. though if the 2 piece OEM valve came apart, or simply hit the piston hard enough it could be pistons, head, and cylinder damage too.
Old May 13, 2007 | 09:07 AM
Its a 98 with a llittle over 21K miles..... sounds like Im gonna have some engine components for sale very soon
Old May 13, 2007 | 09:10 AM
Thanks for the info. Im just going to swap it out to be 'safe' and take the old motor down to cure my curiousity then sell the good parts cheap on this forum to thank all the guys (and gals Im sure) for the help Ive received in such a short time.
Old May 14, 2007 | 07:44 PM
Well I took the valve covers off tonight and the timing chain on the front cylinder is VERY loose. So I guess I am a victim of the evil CCT failure....
Old May 15, 2007 | 07:55 PM
gboezio's Avatar
A leakdown test would tell if the valves are bent.
Old May 15, 2007 | 08:31 PM
Thumper's Avatar
Wheww, I had my original 98 CCT replaced under warranty with the later Honda version and then just this past week i replaced those CCT with my APE CCT.
I hope i don't have them adjusted too tight.
I set them at finger tight minus 1/2 turn while the engine is was cold.
I then rode 250 miles this past Sunday and all seems fine. The engine sure is still quite.
Fingers crossed!
Old May 16, 2007 | 07:54 AM
beesfan's Avatar
beesfan is on a distinguished road
Before you go out and buy a new engine or think about pistons and valve damage, my 98 firestorm had a cct fail and all the symptoms you describe, all i needed to replace was the cct itself, if you're lucky you might not have had any major damage to any of the parts in the engine.
Old May 16, 2007 | 08:23 AM
gboezio's Avatar
a good indicator is the loudness of the "klunk" but do a leakdown test, bent valves don't seal and will let air escape trough the exhaust. Or just put pressure in the cylinder on TDC/fire stroke and listen. At idle, I bet bent valves but ok piston (marked for sure).
A valve job ain't too bad. If a valve snapped off and got chewed by the engine well different thing.
Old May 16, 2007 | 11:24 AM
Babelfish's Avatar
Babelfish is on a distinguished road
Another easy way to check for bendt valves are actually gasoline. That is if the head is allready off. You pour some gasoline in too the exhaust/intake port and wait a few seconds. A healthy valve will keep tight, a bendt one will not, and you will see moist spreading on the other side. BTDT.
Old May 16, 2007 | 02:39 PM
I already bought a new engine (an 04 with less than 5k miles on it) Im going to check the old power plant out really good though. I may have a good engine for sale very reasonable. Since the lock down was at idle I assume, yes I said assume there was very minimal damage to the internals, if any. *fingers crossed*
Thanks for all your help guys, I appreciate it
Old May 18, 2007 | 11:02 PM
Here is what my CCT looks like from my bad cylinder...
Old May 19, 2007 | 05:52 AM
gboezio's Avatar
Damn, blurry CCT's are known to fail,
jk
Well I hope you'll get this running in no time.
Old May 19, 2007 | 01:26 PM
jk
Camera phone man LOL
Old May 19, 2007 | 04:01 PM
That should be longer!
Old May 19, 2007 | 08:13 PM
khanawalt's Avatar
A kind woman....
A man, if married to a kind woman, will never hear that.
Old May 19, 2007 | 09:39 PM
your right.... never heard that before..... thought it.... but never heard it LOL
Old May 20, 2007 | 07:40 PM
GOOD LORD !!!!!! I wish I had read up on the clutch bleeding hassle on these bikes before I took the slave cylinder off thinking I would just bleed it like normal .....(what was I thinking????)
Old May 21, 2007 | 03:25 AM
It's not nerly as hard as it sounds.. But it does take more then "just bleeding" by way of the fitting. Correct angle of the master is required, or you will never get the trapped air out (same as brake master) I find leaning the bike to the right helps with getting trapped air out of the clutch slave.
Old May 22, 2007 | 09:43 AM
used a maunal vacuum pump to pull \most of the air out then just bled it as usual. Now have perfect clutch.
Old Jun 5, 2007 | 06:04 PM
well I finally tore mine down today and the only internal damage that was done was both exhaust valves were bent. You cant even see a mark on the piston. So I have a good set of heads for sale LOL
Old Jun 5, 2007 | 08:06 PM
Pookbe's Avatar
Pookbe is on a distinguished road
After reading all this talk about CCT's, should they be replaced at a certain time or when they fail is as good as any time? I have about 35,000 kms on my bike. I bought it used, he was the second owner and never did anything to it except oil changes and tires. I am not sure if they would have been done before based on mileage or if I can be expecting a treat soon.
Old Jun 5, 2007 | 08:21 PM
All I know is you cant wait til they go bad. Once they go bad you have MAJOR trouble. I had to replace my engine. Most people on here replace the stock CCT's with manual APE tensioners which is what I plan to do. It takes all the guesswork and worry of them failing away.
Old Jun 6, 2007 | 02:41 PM
iamanonymous's Avatar
iamanonymous is on a distinguished road
i just changed to the ape's today and my ccts "look" perfect. is there a way to test them? would anyone be interested in them second hand?
Old Jun 6, 2007 | 02:52 PM
I dont know about testing them. Where did you get your APEs and how much were they if you dont mind my asking?
Old Jun 6, 2007 | 03:00 PM
Pookbe's Avatar
Where and how much are "Ape" chain hangers????
Old Jun 7, 2007 | 03:52 PM
duran's Avatar
duran is on a distinguished road
ugh, I hear a regular noise from my bike right now, 1998, 23000+ miles... I just ordered a new chain, cause I need it, now I'm worried the CCT is about to die and kill my bike.
I've got to get it in to the shop... ugh.
Hangfly
Jul 16, 2015 07:18 AM
Renderw
Sep 10, 2012 07:24 PM
6t8amxetc
Dec 11, 2011 02:55 PM
minispeed
Jul 10, 2009 06:03 PM
Ausie996
Apr 21, 2007 04:13 AM
