Petcock vacuum lines
Old Oct 14, 2025 | 10:54 PM
Slapdash's Avatar
Slapdash is on a distinguished road
I've traced my non running issue to the petcock. I see two vacuum connections on the diaphragm but I only took off one vacuum line. That isn't right is it? Is there one for each carb?
Old Oct 15, 2025 | 06:06 AM
Originally Posted by Slapdash
I've traced my non running issue to the petcock. I see two vacuum connections on the diaphragm but I only took off one vacuum line. That isn't right is it? YES, IT'S RIGHT Is there one for each carb? NO
Old Oct 26, 2025 | 04:48 PM
WallaceWood's Avatar
WallaceWood is on a distinguished road
I just went through this. There's only one vacuum line. It goes from the back of the petcock to the front cylinder. It controls fuel flow for both carbs.
Maddeningly, there's a second thing that LOOKS like a vacuum connection but isn't. My guess is that it's a sprue or a vent or some other artifact from the casting process..
If you're unsure which is which you can connect a vacuum line to the connector, suck on it, and gas will flow.
Your problem is likely the connection at the other end or the line itself.
Old Feb 28, 2026 | 02:24 AM
sbxhau's Avatar
sbxhau is on a distinguished road
I just rebuilt the carbs on my 98’ Valkyrie Tourer. Now my petcock is leaking, so I’m not taken any chances with hydro locking my engine.
snaptube vidmate
poppazuti
Mar 24, 2010 11:22 AM
Mark Morrison
Aug 15, 2008 02:04 PM
Prowlerr
Mar 14, 2008 11:15 PM
gpzturbo
Jun 16, 2007 09:11 PM
Aaron_D
May 31, 2007 09:08 PM
